![]() Join Date: Feb 2008
![]() ![]() ![]() Feedback Score: 6 reviews
![]() it cranks but no start fuel pump is not priming..the fuse is not blown and none of the wiring was mickey mouse..i also changed the fuel pump thinking it was bad.. any ideas..
#3 | |
yea its getting spark just no fuel.. the fuel pump doesnt turn.. i checked voltage at the pump (white/purple wire) because i was told to look there by the head tech at smoothlinez but there is no voltage there.. |
even if the fuel pump burned out ..wouldnt it turn on since i put the new one in.. when it first died it would turn on but then i give gas and it would just die out.. like no fuel pressure.. now it just cranks
![]() Join Date: Oct 2004
Woops didn't read the end of the OP.... if it is new.... not much you can do.... it might be the wiring... Are you gettin power to ecu? Did you check all the fuses... fuel pump relay bad?
#19 |
Is it it called an egi pump relay.... that is just 1 relay right? Is there 2? I dun remember, you can just grab a relay from somewhere else in the fusebox that doesn't matter. Just make sure its the same color.... which I think is green
#20 | |
yea there green but there is 2 one labeled EGI and the other one is EGI PUMP |
#25 | |
You can pick up the relay at autozone. Color won't be the same but just make sure the diagram for the circuit is and you'll be ok. I would bet it's your relay if your fuse isn't blown but the fuel pump isn't getting power.
Check out the coolest new thing: toddrickkkkk.blogspot.com |
