![]() Join Date: Nov 2003
Z32 MAF + Emanage + Redtop
Ok, so i tried searching, but because it wont let you search for anything less than 4 letters, the terms 'MAF' 'Z32' are unsearchable. No help, didnt find anything.
So Im going to finally install my Z32 MAF in my Redtop, and i have an Emanage. What do i need to do in the Emanage, to make that work properly?
-Kyle ![]() |
![]() Join Date: Oct 2004
Come on dude! Change the settings so it says N62 mafs.... Wire the bitch up and go or better yet read the f...ing Greddy Software Manual. If you don't have the software then good luck, cause you can't change it.
If you want I can sell you my ENTIRE SETUP with N62 (Z32) Mafs, Software, Optional Ignition and Injection Harness, with a Tune for 600cc injectors, HKS 264 cams, and Genuine Greddy Software with Cables for 400. (For Redtop)
I already have it wired up and running in my car properly for a stock MAF, I am wondering if I have to change the settings in the software, or with the switches on the side of hte ECU? I have a Emanage Blue, NOT ultimate. Does anyone have a link to the users/software/setup manual in PDF format online?
-Kyle ![]() |
You don't need to retune for Emanage hence > SAFC....
I think you can use the dip switches, but wouldn't try. Software is not free....
![]() Join Date: Jun 2008
i run the map sensor & slider2828 runs the z32 maf. i think he can help you out, and if you tuned your car and it still dosent run right either u have a shitty maf or you need somebody else to tune it.
#16 |
Ok Good, so i dont have to worry about any of the rotary dials on the side of the Emanage its self.
Well that'll be easy then, just to select it from the drop down menu.
-Kyle ![]() |
#17 |
Well thanks for hte help, those of you that actually helped. We put it in this weekend.
It was really easy to do, and the car runs great, cutting pipes and piecing it together ![]() ![]() mocking up ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() We didnt have any clamps to get home with, so Zipties worked until i got ahold of some clamps ![]() ![]() Finally got clamps and finished it up! ![]() ![]()
-Kyle ![]() |
