Old 06-07-2003, 12:18 PM   #1
nguyenk2003
nguyenk2003's Avatar
nguyenk2003 is an unknown quantity at this point
Send a message via AIM to nguyenk2003
Question How 2 turn off Beeping Noise
Hey, How do u TUrn off, or Cut the Line to the Beeping noise when you have your Keys in with the Driver door open. Is there like a Device I Can remove or snip the Wire to deactivate the Beeping noise. I usaly work on my car and listen to music, but when my keys r in, and my driver door is open it gets annoying.
nguyenk2003 is offline   Reply With Quote
Old 06-07-2003, 12:20 PM   #2
WhiteNissanS13
WhiteNissanS13 is an unknown quantity at this point
Send a message via AIM to WhiteNissanS13 Send a message via Yahoo to WhiteNissanS13
i have a s13, it has a little chime noise box thing. its located in the fuse box near the clutch pedal i just pulled the connector out of it.
WhiteNissanS13 is offline   Reply With Quote
Old 06-07-2003, 03:59 PM   #3
maccrank
maccrank's Avatar
maccrank is an unknown quantity at this point
yeah look around ther clutch or underneath the steering wheel in my car it was a yellow plug
maccrank is offline   Reply With Quote
Old 06-08-2003, 05:16 AM   #4
kandyflip445
kandyflip445's Avatar
Close the door.....
My 240 vBgarage
Old 06-08-2003, 08:28 AM   #5
Phlip
Yes, I look like that
Phlip's Avatar
Originally posted by kandyflip445
Close the door.....
Hey, there's an idea c'mon guys, lets hear it for close the door!!!
Weirdo
And I write too!
Old 06-08-2003, 09:02 AM   #6
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
i just cut the wires in the door, and the seat belts still work...
so my question is, where is the switch to make the belts go up/down?
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 06-08-2003, 10:35 AM   #7
Warwick5s
Warwick5s's Avatar
Warwick5s is an unknown quantity at this point
but...if you cut the door wire, wouldn't the dome light not come on either???
just pull off the kick panel by your fuse box. if you have your door open and it's ringing, you'll see a box with a little arm striking something inside. that's your chime - just unplug the harness to it. that way you don't screw up anything else!
Warwick5s is offline   Reply With Quote
