Old 02-12-2009, 06:54 PM   #1
gunmetalrps
gunmetalrps will become famous soon enoughgunmetalrps will become famous soon enoughgunmetalrps will become famous soon enough
Blue-ish smoke from exhaust
i just wanted some feedback.
its a sohc KA. had a rebuilt, resurfaced head, new valve seals/guides about March 08. also new headgasket. its not blowing a lot of smoke only when im at full throttle around 5.5k-7.5k rpms. not overheating AT ALL. still pulls strong. if i drive normal theres no smoke at all. when it does smoke its kinda blue-ish. im thinking piston rings since the block is at about 190xxx. but what about 02 sensor or fuel mixture running rich. i know it cant be the valve seals or head gasket. also, it doesnt seem to be losing much oil( even though the oil pan is kinda leaking oil)
any ideas?
gunmetalrps is offline   Reply With Quote
Old 02-12-2009, 07:05 PM   #2
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
i say it may be your rings, check compression
is the CEL on?
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 02-12-2009, 07:08 PM   #3
Alpha Residence
Alpha Residence's Avatar
Alpha Residence is an unknown quantity at this point
could be something as simple as bad spark plug gaskets as well.
Alpha Residence is offline   Reply With Quote
Old 02-12-2009, 07:12 PM   #4
gunmetalrps
spark plug gaskets? can you go more in-depth?
Old 02-12-2009, 07:30 PM   #5
The Chad
The Chad's Avatar
The Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really nice
He means the rubber rings/gaskets that run along inside the Valve cover. They usually come in a set with a new valve cover gasket. I honestly would say piston rings though. I'm having the same prob, but mine does a quick puff on start off too.
The Chad is offline   Reply With Quote
Old 02-13-2009, 03:56 AM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Do a compression, better yet, leak down test to see if its the rings...
CLICK HERE!!!
Old 02-13-2009, 08:50 AM   #7
rex2sx
rex2sx's Avatar
rex2sx is an unknown quantity at this point
Dont do a compression test. Compression test is for compression rings. Leakdown test would work better. But since you said the head as new guides and seals the only thing i can think of is the tube seals. Ill check around for ya.
rex2sx is offline   Reply With Quote
Old 02-13-2009, 10:50 AM   #8
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
spark plug gasket???? um ok...
on a SOHC with what you say "blue smoke... high rpm", it means 1 or 2 things....
piston rings and/or stem seals
and since you said you have new stem seals then that leaves only the rings.
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 02-13-2009, 11:44 AM   #9
redpotatoes
redpotatoes's Avatar
redpotatoes is on a distinguished road
If there is not much smoke it might be your valve seals. Even if they were done in march 2008, maybe something is wrong there...
redpotatoes is offline   Reply With Quote
