Old 01-26-2009, 07:14 PM   #1
w.tungsten
w.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nice
100 kmph limiter when under ~30*F
This is the only problem I have.
It did not do this a couple days ago when it was 45*F. However today it reared its head again, it's 7*F.
=I know it is a fuel cut, my a/f goes off the chart lean, so I suspected the fuel system (as per zilvia recommendations last winter - fpr, pump, filter) but it never had any trouble with cold/hot starts.
=Has only happened on the freeway.
=Only when it is cold (at or below freezing).
=Happens in 3rd 4th and 5th.
=TP doesn't matter.
=I can cruise at 95kmph all day
SR20DET redtop,
Apexi neo,
Japanese gauge cluster
I would think this is just the SR speed limiter, except 100kmph seems low
thanks for the help
Michael
w.tungsten is offline   Reply With Quote
Old 01-26-2009, 07:40 PM   #2
Monooxide
Monooxide's Avatar
Monooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to behold
How warm is the engine getting?
The ECU may throwing you into a 'limp' mode.
Monooxide is offline   Reply With Quote
Old 01-26-2009, 08:57 PM   #3
w.tungsten
Hmm, could be. the engine warms up to maybe a notch or two under halfway. I believe it's just slightly lower than normal days.
I thought limp mode was rpm based?
Old 01-26-2009, 10:32 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
water temp sensor?
CLICK HERE!!!
Old 01-26-2009, 11:05 PM   #5
w.tungsten
Also, thought those effects were rpm based and made it run rich not fuel cut?
Thanks for ideas though please keep them coming.
Old 01-27-2009, 08:39 AM   #6
fliprayzin240sx
Only reason I say water temp sensor is you said it only does it when it gets to a certain temp. Water temp sensor tells the engine your engine temps. ECU then decides whether or not to add extra fuel or not. When it dumps extra fuel when its not supposed to, makes the car bog real hard.
CLICK HERE!!!
Old 01-27-2009, 02:06 PM   #7
w.tungsten
Right, but I thought it would do that around 2500rpm and/or it was Throttle position based. Not based on speed. My problem will happen in 3,4,and 5th gear, and it won't matter about throttle position.
I can have my foot to the floor and it will still cut. Plus, it is definitely a fuel cut, not bogging down. If I were to describe it, it feels like first it begins to misfire (maybe it retards timing; soft rev limiter?), then it just cuts fuel and I have to wait until speed drops under 100kmph.
*nonetheless I appreciate the idea
Old 01-28-2009, 03:20 PM   #8
w.tungsten
Nobody knows?
Friday I'm putting it on a lift, so I'll be able to unplug the speed sensor, then I'll try it out this weekend see if it fixes the problem.
Old 01-29-2009, 05:02 AM   #9
fliprayzin240sx
Try bumming somebodys ECU and see if it does it with a different ECU.
CLICK HERE!!!
Old 01-29-2009, 07:07 AM   #10
gunluvS14
gunluvS14's Avatar
gunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura about
kmph? you meant km/h or mph? b/c 1 kmph is 1,000mph, not a common unit.
if you have 100mph cut with 3rd, 4th, and 5th, (obviously you can't reach 100mph with 2nd gear), I'm thinking it could be a bad 5th gear position sensor. fuel cut happens at 5,500rpm right?
http://www.zilvia.net/f/image.php?type=sigpic&userid=45706&dateline=118722  3315
gunluvS14 is offline   Reply With Quote
Old 01-29-2009, 09:35 AM   #11
Monooxide
Monooxide's Avatar
Where/when have you seen a 'kilo'-mile per hour(kmph) used? I would LOVE to know that.
Old 01-29-2009, 09:00 PM   #12
w.tungsten
Ya I love driving at 1000mph in 3rd gear, since my engine can rev to 65,000 and all....
yeah I'll definitely bum someone's ecu. I'm still going to go for the speed sensor first since finding an ECU may take some time.
Fuel cut happens at 2.5k in 5th and 3.3k in 4th. Higher in 3rd.
so we're all pretty much banking on something electrical?
Old 01-30-2009, 10:51 AM   #13
fliprayzin240sx
I guess you missed the part where he says he got a JDM Gauge Cluster right?!?! Read the whole thread will yah...stock Silvia speed cut is at 120kmh ish, thats why he brought it up and said he deesnt think its the speed cut since its kicking in at 100kmh.
CLICK HERE!!!
Old 02-02-2009, 02:18 PM   #14
w.tungsten
If anyone was wondering I could not get it on the lift this weekend, someone decided to do a clutch change on an eclipse took all weekend. Sorry, I know it's pretty lame when people post their problems and don't actually try anything to fix it on their own. I'll be able to use the lift Thursday, so I won't update this until I get it on the lift Thursday.
Old 02-14-2009, 02:12 PM   #15
w.tungsten
okay so after trying it out I unplugged the speed sensor and my speedometer stopped working. However the problem still occurred. I did notice that the odometer still worked, so i figure there must be two speed sensors one for the speedometer and one for the odometer.
I'm guessing the odometer plug is the big one that points downwards and to the passenger side at the back of the transmission. It doesn't have a connector until the engine bay. I'm going for it.
I still haven't been able to source a ECU, tomorrow I should be able to use a friend of mines.
Old 02-15-2009, 06:31 PM   #16
w.tungsten
problem fixed unplugging the second sensor did it.
