![]() Join Date: Jul 2008
Trader Rating: (26)
![]() ![]() Feedback Score: 26 reviews
![]() Does anybody know what the resistance in the airbag is so that I can add a resistor to turn off the airbag light
Trader Rating: (26)
that is why i want to find the resistance so i can put a resistor in. that will trick the module into thinking that there is an airbag there, that way the passenger airbag will still work and there will be no light.
Trader Rating: (26)
i would have done that, but there is a high possability that the airbag will deploy when you send current through it to test for resistance.
Trader Rating: (26)
they're in south el monte A Spec Products just call them.
#15 |
![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
considering the auto system runs on 12V, I am surprised people doubted that.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
#16 | |
![]() Join Date: Sep 2006
dunno, IIRC when S14 pass Side air bag deploys it will destroy your dash....if you need new ones i've just disconnected my driver And pass siad air bags....
'95 S14 Se With HKS's - BREMBO's - ES/SPL. |
#17 | |
I bought their short hub w/SRS but the connection on the resistor wire didnt fit the type of connections my S14 has (white connection shown in 1:55 and yellow connection shown in 2:20 of this video). YouTube - NRG Steering wheel quick release how to install 101 tech I carefully broke off the plastic connection on the WB resistor and pulled the resistor off, plugged it on the SRS hub and nothing. The SRS light still blinked. I then tried plugging it on the yellow connection and still nothing. |
#18 | |
Trader Rating: (26)
#19 |
#20 |
![]() Join Date: Dec 2002
No. The ECU has nothing to do with the SRS system. Do a search please, we've covered this a million times, same procedure for diagnostics of the SRS system, key on, depress switch 7 times in 5 seconds, etc.
#21 |
Ok. I did research and got tons of info. I tried the "push 5 times in 7 seconds" just like the manual says but it didn't seem to work. I also tried the "7 times in 5 seconds" and oddly that did work. The code I got was the light turned on for 3 seconds then off for 2,3 seconds and then flashed 2 times. Then it went off and restarted sending the code. I turned the key back to the off position and then pushed it back to the on position, then did the 7 times in 5 seconds. I counted 1-1000, 2-1000 and so on until I did 7 seconds and pressed the door switch one more time. What happened next was the air bag light went back to flashing on and off like in the first place. I tried it over and over on saturday and again today, monday, and it did the same thing. I managed to get it on diagnosis mode time and time again (it gave me the code) then when i tried reseting it would get off diagnosis mode and went back to flashing off and on. By the way, the resistor is plugged on all the way. I also tried disconnecting the car battery but so far no success. I'm driving it around in diagnosis mode right now.
