#2582 |
$238 shipped to you
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
#2587 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
Hey, Dan, I ordered a magnetic drain plug and two MAX stickers on Feb. 14th and I still haven't gotten anything yet. Any way to track the progress? Thanks!
#2591 |
![]() Join Date: Oct 2007
can i get a quote for s14 coilovers shipped to guam 96915
and i alo want to pre order the steering angle nuckle kit will it still be 250 shipped?
#2592 |
can you please give me a quote for wheel spacers one 25mm set and one 30mm 5 lug 114.3 (12x1.25) AND magnet oil drain plug shipped to 78230 AND how much for local pickup?
thanks |
#2593 | |||||
tracking sent via email
tracking emailed $237 allow 7 weeks for delivery. $248 shipped Quote:
I have the Oil plug & have 25mm in stock but not 30mm - they're 1.5 months away. Please let me know how you would like to proceed.
#2596 |
How much for The MAX super angle kit shipped to 95112
found here POWERED BY MAX: スãƒâ€*アリングãÂ®åˆ ‡ã‚Œè§’up Super Steering Angle Parts Also, a full set of ur multi link suspension parts...RUCA, Tie rods and ends...the hole thing. 95112 NEED THIS ASAP. THANKS. |
#2597 | ||
what sizes do you need?
Bent or straight toe rod? BTW we dont sell tie rod ends. Would you like to include subframe collars or solid subframe risers?
#2599 |
Here is the final production version of the MAX Solid Subframe Risers track tested and in production NOW.
Perfect for getting rid of the sloppy OEM rubber bushings. Risers help correct your suspension geometry on lowered cars as well as helping you avoid broken axles. ![]() ![]() Alot of people think you need a press to do this but its near impossible because the thin metal on the subframe around the outside of each bushing will easily become distorted. You can do it with an air saw, you poke the sawblade in the cavity in the OEM bushing and cut a slit in the outer ring OF THE BUSHING being careful not to cut the subframe ring. It helps to saw a little from the top side and a little from the bottom side. Once the slit is cut shove a big flat head screw driver in there and once the tension of the bushing's outer ring is compromised, it just pops right out. To prepare for the epoxy you want to sand the surface. ![]() Mix epoxy - When you buy some the thicker viscosity the better. The brand and type are not important as long as it is made to bond to metal. ![]() The Risers slip right in by hand and are secured permanently with epoxy ![]() ![]() You have to beat the unibody here... especially if you dont have MAX GII camber arms. You also have to redo the e-brake cable routing bracket. ![]() With this second version of the solid riser the bottom part is half as thick so you can slice off the extra threads that are no longer needed so you have more dirt drop ground clearance in case your wheel slips off the track. ![]() ![]() The half thickness in the bottom part of the rizer also really helps if you are trying to use a straight toe rod on a really low car. Of course if you are on top of your game you already have the MAX GII bent toe rod = ) ![]() We should have these on or around march 25th you can pre order now if you wish to reserve a set They are only $100 plus shipping for a set of 4.
#2604 | |||
![]() Quote:
$750 shipped for front and rear big brakes
#2605 |
![]() Join Date: Mar 2006
ok so these (risers) are super awesome!
my car felt really good at top drift this weekend. 2 events ago i broke my drivers side axle (twice), so two of em in one event this event i didnt even break a boot because the max subframe risers help with the axle angle as you can see in the photo. they also help with suspension geometry as you can see in the photo as well if you look at my LCA and stuff. Some other cool things that you wouldnt think of till they are on- they allow you to make your exhaust higher by the diff if you want to which if youre low is a very weak point on the exhaust since it is like an inch off the ground there. Also, since it physically makes your subframe higher in your car, it helps for bottoming out your subframe. ive cracked my subframe twice before so this is a major issue and a good thing to help. One thing that wasnt expected is that it changed my wheel fitment, since the LCA is so angled up, naturally when you lessen that angle it pushed the wheel out, about 5mm on my setup. Overall these are super awesome, install is pretty easy just takes a few hours even if you dont have crazy tools/shop. Did some of this with them- ![]() Do it!
driftparty.com |
#2610 |
wow my life is complete.. haha
thank you for making these! now what about the front? or actually, the super angle kit also makes the tie rod bolt up lower making it more level right? gosh these are amazing... |
