Old 03-19-2009, 07:13 PM   #1
bruceguy
bruceguy's Avatar
bruceguy is an unknown quantity at this point
dash replacement: do you bother changing the vin?
well... when i picked up my s13, the dash was soooo ffuuuucked it was not worth fixing.
i went to the junkyard and found a nearly perfect dash, so i picked it up for less than 15 bucks!!
im gonna replace the dash tommorow, then it occured to me, should i rock the new vin on the dash?????
what are the pro/cons of having a different vin?
-can you aviod parking tickets?
-if you get pulled over, would cops be like WTF!?!?
lets discuss.
bruceguy is offline   Reply With Quote
Old 03-19-2009, 07:18 PM   #2
gyula hlavati
gyula hlavati's Avatar
gyula hlavati is an unknown quantity at this point
I just used my original VIN plate on my new dash.
gyula hlavati is offline   Reply With Quote
Old 03-19-2009, 07:21 PM   #3
s13boy89
s13boy89's Avatar
s13boy89 is on a distinguished road
Send a message via AIM to s13boy89
if you get pulled over and the vin does not match you get in a lot of trouble
I have kids running around here I dont want to use an xxr as a coffe table
s13boy89 is offline   Reply With Quote
Old 03-19-2009, 07:23 PM   #4
palmdale_mob
palmdale_mob's Avatar
palmdale_mob is an unknown quantity at this point
I once saw a thread in here where the guy got his car impounded because the numbers didn't match
or maybe a ticket, I don't remember
palmdale_mob is offline   Reply With Quote
Old 03-19-2009, 07:24 PM   #5
ThatGuy
Admin Asshole
ThatGuy's Avatar
Leave the junkyard vin on, get pulled over. While you're car is impounded, you can decide if the 5 minutes it would have taken to drill the old rivets and pop on two new ones would have been worth it.
Old 03-19-2009, 07:25 PM   #6
HPballer76
HPballer76's Avatar
HPballer76 is an unknown quantity at this point
just put your old vin on the new dash.
HPballer76 is offline   Reply With Quote
Old 03-19-2009, 07:25 PM   #7
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
I changed my dash and actually forgot to change the vin plate. When I went to go smog it, everywhere I took it all the techs freaked out and would not even touch the car even when I explained the situation and showed them the other places where the vin matches. So instead of removing the dash again I just ripped the vin plate off with out damaging anything. I highly recommend saving yourself the pain that I went through and remove or transfer the vin plate. I can't imagine the even worse pain in the ass it would have been if I got pulled over or something.
mxexux is offline   Reply With Quote
Old 03-19-2009, 07:27 PM   #8
iloveturbos
iloveturbos's Avatar
iloveturbos is an unknown quantity at this point
u have got too be one of the dumbest people on the face of the earth ..u can not be serious ...get a drill , get a 1/8 of a inch drill bit ...drill out the rivits on ur old dash ...do the same too the new one ..go to home depot and but some drop ceiling rivits (cheap) and a rivit gun...put ur vin on the new dash and use the rivits ..c'mon i cant even belive u asked that question..do it the right way ..save your-self alot of hassle from the cops ...
iloveturbos is offline   Reply With Quote
Old 03-19-2009, 07:53 PM   #9
w0nderbr3ad
Trader Rating: (50)
w0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to all
Feedback Score: 50 reviews
Send a message via AIM to w0nderbr3ad
Just do it. Save your self some reassurance. Doesn't take 5 min to put your old vin plate on your new one.
w0nderbr3ad is offline   Reply With Quote
Old 03-19-2009, 08:52 PM   #10
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
definitely change it out, but don't admit to ever doing it to a cop.
JRas is offline   Reply With Quote
Old 03-19-2009, 08:52 PM   #11
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
When in doubt...
call the department or agency that handles vehicle registrations in your area. They should be able to tell you what the proper procedure for this type of situation is.
HalveBlue is offline   Reply With Quote
Old 03-19-2009, 09:05 PM   #12
jrocslider
jrocslider's Avatar
jrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfection
was answered by everybody.
common sense.
i changed mine when i replaced my old dash. the extra 5 minutes it takes to do it is really worth it.
jrocslider is offline   Reply With Quote
Old 03-19-2009, 09:11 PM   #13
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Weird.
I put a new dash in my car,
but
I had to cut my dash in the coners for my cage to fit through.
I chopped off the corner of my old dash with the VIN and keep it in my glovebox.
Maybe I'll try to attach it somehow.
http://bhworld.wordpress.com/
Old 03-19-2009, 09:13 PM   #14
gyula hlavati
Common sense.
I changed mine when i replaced my old dash. The extra 5 minutes it takes to do it is really worth it.
common sense.
Old 03-19-2009, 09:16 PM   #15
HungryHank
Location: 123klan - Southern California Baby Killer Gang
HungryHank is an unknown quantity at this point
I got my car without a dashboard. ( shell )
if I bought another dashboard and replaced it and that one had no vin attached what should I do?
just ask the dmv to reprint one or make a copy?
HungryHank is offline   Reply With Quote
Old 03-19-2009, 09:24 PM   #16
bruceguy
bruceguy's Avatar
damn, judging by all your reactions, this is a pretty fukin serious matter!
i know this was pretty much a dumb question, but now i know the consequences of "forgeting" to change the vin.
its funny how u guys emphasize the importance of legit shit, but yet u guys have sr20 and rb25 engines that where design to fail smog..hahaha
thanks for your time
Old 03-19-2009, 09:43 PM   #17
hapa_s13
hapa_s13 is an unknown quantity at this point
yeah, I swapped my dash and ripped off my vin..I lost it
Ive been lucky soo far but to be honest, I always forget I swapped it.
About the parking ticket topic though, I think it depends on where you are. I live in SF and I got a street cleaning ticket. My original VIN was on, nothing obstructing the view of it, yet on the ticket, it said that VIN was not readable. SO iono..but to be safe, I say replace/swap it.
hapa_s13 is offline   Reply With Quote
Old 03-19-2009, 11:56 PM   #18
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Yes, change the VIN. Its easy. My is swapped, and it doesn't look out of place at all.
-Kyle
Old 03-19-2009, 11:59 PM   #19
cc4usmc
cc4usmc's Avatar
A stolen car and a motor swap aren't the same. One will send you to prison, the other will get you a fine. And they weren't designed to fail smog...
This forum requires that you wait 120 seconds between reporting posts. Please try again in 115 seconds.
Originally Posted by s141996 View Post
is this exhaust california friendly? thnx lmk
cc4usmc is offline   Reply With Quote
Old 03-20-2009, 08:11 AM   #20
aznpoopy
aznpoopy's Avatar
this shit is serious. like seriously serious.
here in NJ, merely tampering with the VIN plate = felony = up to 4 years in prison + never get a decent job again. the statute doesn't give a flying fuck if you own both the new dash and the car legitimately. you are not allowed to tamper with VIN plates, PERIOD. if you get caught you will be at the minimum out alot of money, and at the maximum fairly fucked for a long ass time.
local got totally owned by this. cost him about $2k to hire a lawyer and pay all fees to get it all cleared up .
i highly suggest you guys get it done properly, especially considering how easy it sounds. the proper method, btw, is definitely NOT swapping the vin plates.
proper way for you cali dudes:
http://zilvia.net/f/1941110-post37.html
Old 03-20-2009, 08:33 AM   #21
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
Oh christ, I was wondering about this. I threw the old dash out cause it was trashed and didnt grab the tag off it. fuck fuck fuck.........doesnt the vin under the hood count? Then again I am in florida.....the cops might not even care lol
Originally Posted by atutt View Post
Or you could have stopped being a lazy asshat and done some research.
Otto347 is offline   Reply With Quote
Old 03-20-2009, 09:36 AM   #22
Trutrax
Trutrax's Avatar
Trutrax will become famous soon enoughTrutrax will become famous soon enoughTrutrax will become famous soon enoughTrutrax will become famous soon enoughTrutrax will become famous soon enough
What if you just rip the cars vin off the old dash and glue it over the the vin of the new dash?
Trutrax is offline   Reply With Quote
Old 03-20-2009, 09:50 AM   #23
aznpoopy
aznpoopy's Avatar
florida:
319.33 Offenses involving vehicle identification numbers, applications, certificates, papers; penalty.--
(1) It is unlawful:
(d) To possess, sell or offer for sale, conceal, or dispose of in this state a motor vehicle or mobile home, or major component part thereof, on which any motor number or vehicle identification number that has been affixed by the manufacturer or by a state agency, such as the Department of Highway Safety and Motor Vehicles, which regulates motor vehicles has been destroyed, removed, covered, altered, or defaced, with knowledge of such destruction, removal, covering, alteration, or defacement, except as provided in s. 319.30(4).
(6) Any person who violates any provision of this section is guilty of a felony of the third degree, punishable as provided in s. 775.082, s. 775.083, or s. 775.084. Any motor vehicle used in violation of this section shall constitute contraband which may be seized by a law enforcement agency and shall be subject to forfeiture proceedings pursuant to ss. 932.701-932.704.
775.082. Penalties
(d) For a felony of the third degree, by a term of imprisonment not exceeding 5 years.
775.083. Fines
(c) $5,000, when the conviction is of a felony of the third degree.
pray you never get caught dude. lol.
Old 03-20-2009, 09:59 AM   #24
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
lol doesnt matter if the vin matches in other places. that just means your rockin a stolen dash
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 03-20-2009, 10:20 AM   #25
ericcastro
ericcastro's Avatar
They werent designed to fail smog.
jeez, im trying to be nice........
It all depends on the officer.
Being in the valley.
and with your attitude.
you probably will get fucked.
Me being in LA.
Not trying to scam my way out of tickets and acting like an adult, prolly be just fine.
Your mind set is way off dude.
Guess it can be expected though, coming from the Valley
Change the way you think about that shit, its just gonna fuck you over later in life.
Dont make everything a scam and a lie, cause then you gotta stress and worry. That shit will eventually fuck you over, time and time again.
do your friends have the same mentality as you?
How are they doing?
Just do it the right way, and you will be good.
Any questions, talk to an officer or the DMV.
remember, you pay thier salaries, so utilize them.
Old 03-20-2009, 10:28 AM   #26
s13.dark1
s13.dark1's Avatar
s13.dark1 is making a name for him/her selfs13.dark1 is making a name for him/her self
change it.. easy 1-2-3 no worries
you better cut, weld, and paste that sh!t
http://zilvia.net/f/sale-items/24340...kets-more.html
s13.dark1 is offline   Reply With Quote
Old 03-20-2009, 10:29 AM   #27
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
pretty much what i have done for everyone if helped replace there dash boards.
to OP...honestly, this was without a doubt one of the dumbest questions asked in this section of the forums, you would think common sense would kick in and tell yah "yeaaaaa, ur gonna wanna take that off no questions needed on the matter", none the less, just dont leave it on there, and if u can salvage YOUR Vin, do so.
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 03-20-2009, 10:35 AM   #28
YoungGun
YoungGun's Avatar
I never switched mine from the old one to the new one, but i've heard people go to jail overnight for different vin on the dash, I would change it out.
YoungGun is offline   Reply With Quote
Old 03-20-2009, 10:36 AM   #29
Enna
Enna will become famous soon enoughEnna will become famous soon enoughEnna will become famous soon enough
Send a message via AIM to Enna Send a message via MSN to Enna
Shit when I replaced my dash last year I swapped it w/o a second thought. Its just stupid to not do it.
Originally Posted by soreballz View Post
I hoped the candy would make it delicious, but I was incorrect.
Enna is offline   Reply With Quote
Old 03-20-2009, 10:49 AM   #30
Otto347
Otto347's Avatar
Well then im fuct..........
