Old 03-20-2009, 08:47 PM   #1
Got240sx
Trader Rating: (-1)
Got240sx is an unknown quantity at this point
Feedback Score: -1 reviews
help with my suspension
I have a stock S13 hatch and the suspension is horrible. The car shakes and wobbles after 65mph and sometimes when I coming to the stop the car wobbles too.
What suspension parts do you guys suggest? coilovers or more?
Looking to start with suspension mods first then touching the motor later.
Thanks
Got240sx is offline   Reply With Quote
Old 03-21-2009, 11:37 AM   #2
Got240sx
Trader Rating: (-1)
bumperoo #1
Old 03-21-2009, 11:56 AM   #3
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
the shaking and wobbling @ 65mph sounds more like a tire rotational issue than a suspension issue. I'd check out the rotation of you tires first, you don't want to spend loads of money on something that wont fix your problem ykno?
@adrianfromthecastle
Old 03-21-2009, 01:48 PM   #4
Got240sx
Trader Rating: (-1)
Well my friend that i bought the car from said the rear shocks were bad/blown. Im guessing that could be one of the problems?
Old 03-21-2009, 01:52 PM   #5
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
If it's blown it will bottom out over bumps and clunk, if you look at it it's probly leaking too. So, you can spend a couple hundred $$$ on new suspension that you think is the problem or you can spend $10 and have the tires balanced. I'd have the tires balanced first. Just my $.02
HYPNOTIK is offline   Reply With Quote
Old 03-21-2009, 01:53 PM   #6
Got240sx
Trader Rating: (-1)
Thanks, will get the tires balanced first and see if it still wobbling.
Old 03-21-2009, 02:12 PM   #7
Ceepo
Ceepo's Avatar
Get tires balance, and change the pads and rotors(sound warped) then get back to us...
Old 03-22-2009, 03:24 AM   #8
idlafie
idlafie's Avatar
Before you get your tires balanced, and change your pads & rotors, (warped rotor will be felt when stepping on the brakes - your brake pedal will oscillate). check to see if all your lug nuts are tight. Loose or missing lugnuts/wheel studs can cause a shimmy or wobble. Inspect your rim to see if the wheel weights balancing your rim are still in place, (they sometimes fall off throwing your wheel/tire out of balance). Jack the front end of your car up & put it on jack stands. With the front end up & on jack stands, grab the tire/rim/wheel with both arms and push/pull/tug. You are checking for play in your wheel bearings. Bad wheel bearings can also cause your shimmy / wobble. Also check your lower control arm ball joints & tie rod end joints. While you are at it, also check to see if your lower control arm hasn't cracked where the tension control rod connects to it. All of these items can possibly lead to a wheel wobble / shimmy.
Anyhow, hope this helps....
ID
Old 03-24-2009, 10:08 AM   #9
Got240sx
Trader Rating: (-1)
ID
Thanks for the help,
Ive also noticed that it wobbles more when im actually braking. Could that be my rotors are warped?
Old 03-24-2009, 10:11 AM   #10
SILVIA_KIDs14.5
SILVIA_KIDs14.5's Avatar
Trader Rating: (-1)
SILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choices
ummm....how bout an alignment and balance of the wheels and or new brakes and rotors don't sound like a suspension prob to me more like mantianance
SILVIA_KIDs14.5 is offline   Reply With Quote
