Old 03-22-2009, 02:19 AM   #1
prodigys14
prodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choicesprodigys14 has made poor choices
sohc bogging
having a problem with my 89 s13 bogging out at start up and bogging down to about 200 rpms for a second or so then it would rev back up everytime i step on the gas, seems like it only occurs when the motor isnt warmed up... im guessing the maf sensor?... also while driving today i lost a good amount of power and the car started sounding like a wrx, what is the most probable cause of one of the cylinders to not fire? keep this in mind that i just bought the car few days ago and have no idea whats been replace and what not. any help would be greatly appreciated
prodigys14 is offline   Reply With Quote
Old 03-22-2009, 02:32 AM   #2
gotspins13
gotspins13's Avatar
gotspins13 is an unknown quantity at this point
Send a message via Yahoo to gotspins13
check your maf if not then look for places were it might be sucking up air it doesnt need, then check if your running on 3 or 2 or 1 cylinder hahaha to test that just pull the spark plug wires one by one while its running and listen for a difference as in struggling
perfectly said! FJ20ET 16 valve - the holy grail of Nissan engines
gotspins13 is offline   Reply With Quote
Old 03-22-2009, 03:57 AM   #3
prodigys14
yea did that and found out cylinder 1 isnt firing but its giving spark tho... so im wondering if it could be the injector?
Old 03-22-2009, 05:03 AM   #4
rocksteady_racer
rocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her self
Send a message via AIM to rocksteady_racer Send a message via Yahoo to rocksteady_racer
Probably. Sounds exactly what happened to my motor. I checked each spark plug and the one that ran differently when I unplugged I replaced the injector on. It was on my 91 240 so my 96 maxima injector fit right in there. So I'd try that first. My KA24e was doing the same thing on my first cylinder and I thought it was the injector so I replaced and the motor still running horrible so I gotta run a compression test and figure out what I have to rebuild. But yea definately start with the injector and see where that takes you.
rocksteady_racer is offline   Reply With Quote
Old 03-23-2009, 07:45 AM   #5
prodigys14
well the car finally came to a point that it didnt start, i towed it home and left it alone for a good 3 hours, came back home and tryed to start it again and it started but ofcourse it was bogging out, finally got it to idle on its own but everytime id rev it the motor would bog with gas smoke coming out the exhaust so would it be that my ecu is acting up and dumping too much gas this whole time??? btw thanks for the info rocksteady
Old 03-23-2009, 07:49 AM   #6
drifter_for_life06
drifter_for_life06's Avatar
drifter_for_life06 is making a name for him/her selfdrifter_for_life06 is making a name for him/her self
Send a message via AIM to drifter_for_life06 Send a message via Yahoo to drifter_for_life06
did you replace that injector on cyl 1? the computer might be trying to compensate for a really lean cylinder one by adding more fuel on 2-4
RPS13: +.020" 2871r 264's AEM EMS
http://enjukuracing.com/#_l_4s
drifter_for_life06 is offline   Reply With Quote
Old 03-23-2009, 08:45 AM   #7
socalPignose
socalPignose's Avatar
socalPignose is an unknown quantity at this point
lol that happen on my car too and one of my injectors was leaking cuz the seal was broken
socalPignose is offline   Reply With Quote
Old 03-24-2009, 02:42 AM   #8
prodigys14
pretty sure its not a leaky injector i dont see or smell gas where the injectors are... im just gonna try put in another ecu and hope for the best
