Old 03-22-2009, 07:03 PM   #1
yabeet
yabeet's Avatar
yabeet is an unknown quantity at this point
SR Transmission Sensors
Just double checkign as I cant seem to find it on here, the small sensor just forward of the shifter is the reverse lights sensor, the one nearest to the bell housing is the tach sensor and the one with the 10mm bolt holding it in is the speed sensor?
I tried to find a pic too specifically with the side of the trans with the sensors on but had no luck with that either.
If there is a thread with this, could someone please me and link to it.
Thanks!
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’
Jeremy Clarkson on Automatics
yabeet is offline   Reply With Quote
Old 03-22-2009, 07:33 PM   #2
Sileighty_85
Sileighty_85's Avatar
There is no tach sensor on the Tranny, Yes the one with the 10mil bolt is the speed sensor
there is one sensor and two switches on the SR tranny Speed sensor, Reverse Switch and Neutral Switch
But Courtesy Nissan show three switches on their IPB it show a Neutral,Overdrive,Reverse although it under the 240SX tranny
http://www.courtesyparts.com/240sx-p...1487_1501.html
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-22-2009, 07:38 PM   #3
yabeet
yabeet's Avatar
Shizzle, my tach does not read. Only had the thing started up and idled. Are you able to educate me on where my tach should be reading? Thanks...
Old 03-22-2009, 07:40 PM   #4
Sileighty_85
Was the Car a SOHC before?
If so then you need to install the the Tach from a DOHC Cluster
後輪駆動車1番
1986 SR86 - 200ish
Old 03-22-2009, 07:50 PM   #5
yabeet
yabeet's Avatar
It was a SOHC digital cluster w/ HUD, but I changed to a CA18DET digital HUD cluster. The speed reads but the tach needle just sticks at zero.
This is not good news...
Old 03-22-2009, 07:57 PM   #6
Sileighty_85
Im not sure if the CA and the SR Tachs will work if swapped but get a DOHC or SR Tach and just swap it out, you can swap just only the tachs
後輪駆動車1番
1986 SR86 - 200ish
Old 03-22-2009, 08:03 PM   #7
yabeet
yabeet's Avatar
Thanks, appreciate the help sileighty_85. Nothing but sound advice.
And if anyone on here knows about differences between wiring on CA and SR clusters please let me know, thanks!
Old 03-22-2009, 08:14 PM   #8
Sileighty_85
well i meant i didnt know if the CA tach works with the SR.
Just pulling out the tach itself and putting in the SR or DOHC one should fix ur problem
後輪駆動車1番
1986 SR86 - 200ish
Old 03-22-2009, 09:12 PM   #9
yabeet
yabeet's Avatar
Well I just did some reading up on an Aussie forum and that the CA tach is similar to the NA sohc tach in terms of voltage.... ah well. Im going to dig some more and verify that.
