Old 03-25-2009, 05:48 PM   #1
silvia240
silvia240's Avatar
silvia240 is an unknown quantity at this point
Question about zenki turn signal assembly - did a search
So someone stole these off my car ( out of all the things to steal, why these)
Front turn signals
and then cut the wire
So my question is is there a clip that is supposed to be attached to the end of that wire?
I called my local nissan dealer and he doesn't know squat. He told me he does not know if the wire is a clip or is just spliced in.
So if anyone would be kind enough to help, I would like to know exactly what parts I would need to fix this. And if you have the parts to sell, that would be even better.
Thanks for your help.
silvia240 is offline   Reply With Quote
Old 03-25-2009, 06:44 PM   #2
projectRDM
projectRDM's Avatar
The dealer sells a 2pin plug. Whether or not it fits is up to you, you may have to grind the tab off. Check Courtesy's site for more info.
FORMERLY R240NA
Old 03-25-2009, 07:16 PM   #3
silvia240
silvia240's Avatar
Ok, so the question I still have is that is there a plug that goes behind Part # 26124M ?
Because as you can see, mine has been cut to the bare wire. Or does the bare wire go into the part 26124M?
Old 03-25-2009, 07:42 PM   #4
Enna
Enna will become famous soon enoughEnna will become famous soon enoughEnna will become famous soon enough
Send a message via AIM to Enna Send a message via MSN to Enna
No its just the plug. The plug holds the bulb, then it screws into the housing. Thats about it. If anything just check the forsale section for someone selling what you need, or post a WTB.
Originally Posted by soreballz View Post
I hoped the candy would make it delicious, but I was incorrect.
Enna is offline   Reply With Quote
