Old 03-29-2009, 05:14 PM   #1
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
KA ka24e early fuel cut
hey guys just having some problems with my 89' sohc. i searched and searched but nothing
problem is that it hits an early fuel cut in 3rd at around 5000 Rpms, 4th 5000 as well, and 5th gear at around 3900-4100. what can be causing this? I'm pretty sure it's not timing. i also checked my MAF and its good
any suggestions?
thanks
R@ddy is offline   Reply With Quote
Old 03-29-2009, 05:21 PM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
things to look at not saying there your prob but just overview them fuel filter, injectors,MAF but you said you already looked at it, TPS sensor, harness for the injectors, air temp sensor, and vacume lines good luck man =]
s13 @ fullboost is offline   Reply With Quote
Old 03-29-2009, 07:06 PM   #3
toointoxicated62
toointoxicated62 is an unknown quantity at this point
replace fuel filter with a z32 filter its probably dirty as hell unless you replaced it recently
toointoxicated62 is offline   Reply With Quote
Old 03-29-2009, 09:15 PM   #4
R@ddy
Trader Rating: (32)
^^could be...looks like the previous owner didn't take care of shit!
going to buy it soon
Old 03-30-2009, 09:54 AM   #5
toointoxicated62
alright let us know if that fixed it =]
Old 04-08-2009, 05:55 PM   #6
R@ddy
Trader Rating: (32)
ok, so i got a z32 fuel filter, and the same shit.
ugghhhh! im tired of this shit! can anyone help me out?
Old 04-13-2009, 09:31 PM   #7
R@ddy
Trader Rating: (32)
found the problem. well i have HUD on my car and since its not working and the cluster lights don't turn on, i guess its not sending a signal from the speed sensor to the ECU, which is causing it to have some sort of an early rev limit. for some weird reason my cluster lights decide when they want to work or not and when it lights up, it works perfectly fine.
Old 05-01-2014, 01:14 AM   #8
dillondet
dillondet's Avatar
dillondet is an unknown quantity at this point
so buying a new cluster and replacing it fixed your problem? I have a similar problem with my 95 s14 zenki too, It has a fuel cut on 5th gear around 2500rpm, the rest of the others are fine. But on the freeway it cuts the fuel.
dillondet is offline   Reply With Quote
