Old 04-01-2009, 01:16 AM   #1
Om1kron
Om1kron's Avatar
Car wont start... S13sr in S14
cliffs.
coil pack sub harness was pinned incorrectly, therefore causing 1 and 3 to get hot when trying to turn over. Re-pinned it following the ignition chip, still wont start.
So... I will update my build thread in a bit. Here is my dillema...
car cranks
is getting fuel
i'm getting spark
there is probably something else I should say that makes me sound smart, but i'll leave that.
Only thing that is not grounded is the alternator, so the battery is not going to get charged. I have a battery charger hooked up to the battery so it doesn't drain trying to start the car. So power is there.
Here is my current pinout.
From the engine harness.
Male Plug
1. L/R
2. R/G
3. R
4. nothing
5. R/W
6. R/L
From the sub harness.
Female plug
1. R
2. R/G
3. B/Y
4. B
5. R/W
6. nothing
I think something is mixed up here =(
halp I cannot find a pin out for these two things and it's an S13 SR. Someone please take a picture of their pin out and write down your wire order for me... (cough jeff jordan.)
Wayne Edwards
https://om1kron.blogspot.com
Om1kron is offline
Old 04-01-2009, 12:13 PM   #2
Om1kron
Om1kron's Avatar
ok, found this thread. going to give it a go in a minute.
S14 SR20DET Coil Pack Wiring Harness: 240SX Technical Forum: Nissan Forums / Infiniti Forums - NICOclub
thanks for all of the responses guys (sarcasm.)
Wayne Edwards
Om1kron is offline
Old 04-01-2009, 12:28 PM   #3
Om1kron
Om1kron's Avatar
after double checking it... he has his harness plugged up the same way I do mine. =(
Wayne Edwards
Om1kron is offline
Old 04-01-2009, 12:57 PM   #4
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Timing perhaps?
KiLLeR2001 is offline
Old 04-01-2009, 01:58 PM   #5
Om1kron
Om1kron's Avatar
not timing, cas hasn't been removed. car ran before in previous car. No need to check timing, it's the same as before when engine ran.
Wayne Edwards
Om1kron is offline
Old 04-01-2009, 02:47 PM   #6
driver11324
driver11324's Avatar
driver11324 is an unknown quantity at this point
I'm sorry to hear it doesn't start after all of that work. Ill check my harness tomorrow for you when I go to work on my car.
driver11324 is offline
Old 04-01-2009, 07:13 PM   #7
Om1kron
Om1kron's Avatar
we've been in the garage all day, checked timing just in case... spot on, tried my ignition chip and ecu in another redtop car, works just fine. checked all of the wiring with a multimeter, grounds and power, all butter.
GSXRJordan recommended tooling around with some black wire on the e19 plug. But that goes to the alternator and other random plugs on the tranny.
also recommended checking the starting signal wire, but nothing is wrong with that.
car even cranks without the ecu relay attached which it shouldn't.
I'm pretty much a few more decisions short before tearing the whole harness apart.
Wayne Edwards
Om1kron is offline
Old 04-01-2009, 07:27 PM   #8
Supercowboy
Supercowboy is an unknown quantity at this point
A few things are the plugs wet? If not Spray some carb cleaner in the intake somewhere and crank the motor. If its flooded shut the fuel pump off and crank the motor with the TB wide open. Check to make sure ECU grounds are clean. Make sure coil packs are grounded. Does the car backfire or try to start. This is a stupid question but make sure the fuel feed and return line on The right way. I just did some work on a guys car and those were reversed and he couldnt get it started.
Supercowboy is offline
Old 04-01-2009, 07:35 PM   #9
slider2828
slider2828's Avatar
Try a new ecu.... Seriously! You might have toasted it as spark runs through the ecu. I had the same problem and it was the ecu. I shorted my mafs and my ecu was gone. I would try that before anything. Keeps you fromt ripping apart your harness
I have a known good ecu if yu want, but yeah see if you can get a ecu to try out.
Turn and Burn!
slider2828 is offline
Old 04-01-2009, 07:50 PM   #10
Om1kron
Om1kron's Avatar
tried the ecu in another s13 sitting in my yard. worked just fine.
fuel pump is no longer priming now.
now the ecu may be toasted.
Wayne Edwards
Om1kron is offline
Old 04-02-2009, 12:39 AM   #11
Om1kron
Om1kron's Avatar
tried the ECU in another 240, wouldn't start. Fuel pump wont prime. So it's official, I biffed my ecu.
I'm going to redo the bottom half of the engine harness next week while wrapping up the rest of the wiring. Granted I cannot start the car yet, I can still finish up the electrical system on the car.
oh well.
Wayne Edwards
Om1kron is offline
Old 04-03-2009, 01:45 PM   #12
Om1kron
Om1kron's Avatar
re-did the lower harness wiring, car fired right up. will have a video update to my blog later today to show how I fixed the ecu.
Wayne Edwards
Om1kron is offline
Old 04-03-2009, 01:49 PM   #13
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
awesome do u know what exactly in the lower harness was the problem?
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline
Old 04-03-2009, 01:51 PM   #14
Om1kron
Om1kron's Avatar
not one fucking clue. I just undid the f2 ecu relay and redid all of the contact wires, and shortened all of the wires so there was no more elephant trunk branching off of the wiring harness.
But I branched the ecu constant power into the switched power on accident, I need to go fix that right now. The car wont shut off unless I pull the 7.5 amp fuse and turn the key off.
whoopsie.
Wayne Edwards
Om1kron is offline
Old 04-03-2009, 06:19 PM   #15
drkidd22
drkidd22 is an unknown quantity at this point
Might have had a loose connection? I had problems with my SR as well and it turned out it was just my timming
drkidd22 is offline
Old 04-03-2009, 07:05 PM   #16
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
wanye is the fuckin man i'm glad you haven't given up homie
MAAAD props!!!
<3
-los
los_inc is offline
