Old 04-01-2009, 03:31 PM   #1
koranth
koranth is an unknown quantity at this point
KA sputtering ka not a steady idle missing real bad please help me!!!
Rough idle all the way to 4 grand then it will clean up . Without gas it will die i have replace .....
temp sensor,
all my injectors,
spark plugs & wires,
cleaned the maf, and
cheaked for vacume leaks
i'm getting spark
any ideas ill be happy to hear them please help! Could it be timing,tps, ecu i dont want to hit another dead end.
koranth is offline   Reply With Quote
Old 04-03-2009, 03:59 PM   #2
nismo tuned s14
nismo tuned s14's Avatar
nismo tuned s14 is making a name for him/her selfnismo tuned s14 is making a name for him/her selfnismo tuned s14 is making a name for him/her self
It might be the intake manifold gasket.
nismo tuned s14 is offline   Reply With Quote
Old 04-03-2009, 06:12 PM   #3
sil8tyhavoc
sil8tyhavoc is on a distinguished road
Send a message via AIM to sil8tyhavoc Send a message via Yahoo to sil8tyhavoc
damn this recently happened to me......check your EGR. pull of the bigger hose off the intake pipe and see if it comes down. if it does, its the EGR if doesnt you might wanna check for vacuum leaks, gaskets, PCV valve. good luck....
sil8tyhavoc is offline   Reply With Quote
Old 04-04-2009, 02:33 AM   #4
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
but.. but.....The bigger hose on the intake is the IACV
disconnecting that will stall your motor anyways.
EGR is all the way in the back buddy.
you can see the vacuum source for it and its bolted right to the manifold.
also check your timing.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
ka24de s13 sputtering ka
