Old 04-01-2009, 04:42 PM   #1
Folken
Folken's Avatar
Folken is an unknown quantity at this point
Crank pulley help
So I have ca18det and i'm trying to change the timing belt but my crankshaft pulley bolt is torqued down by god or something, I put the car in 1st w/ the e-brake up, using a breaker bar, and after a few good rotations the car turns over and backs up alil, I don't have Air at my place and I'm trying to refrain from buying an electric impact or lodging the breaker bar and cranking the engine, anyone have any tips on getting this bolt loose? i'm going to pick up a strip wrench but i doutb that'll hold.
The beatings will continue until moral improves
Folken is offline   Reply With Quote
Old 04-01-2009, 04:50 PM   #2
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
You need an Impact Gun to break it loose !!! (Air tool)
WoolyS14DET is offline   Reply With Quote
Old 04-01-2009, 05:04 PM   #3
Folken
Folken's Avatar
thank you for missing the point
Old 04-01-2009, 05:06 PM   #4
n240sxfnatic
n240sxfnatic's Avatar
n240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond repute
Dont be a pussy jkjk, but seriously, Ur car should not be rolling in gear. Since it is put something under the wheel to stop it, spray some pb blaster, wait a min then use said breaker bar, If you cant get it get a bigger beaker bar. Air tools are over-rated.
n240sxfnatic is offline   Reply With Quote
Old 04-01-2009, 05:12 PM   #5
WoolyS14DET
Trader Rating: (18)
My suggestion is the safest and most direct option with having to do or pull some sketchy ishh. Good Luck
Old 04-01-2009, 05:13 PM   #6
Folken
Folken's Avatar
haha, i know snap-on and matco sell power impact bars that u hit w/ a hammer but god knows how long it'll take to get, while this thread is up... i'm going counterclockwise the crankshaft bolts on this aren't reverse threaded are they?
Old 04-01-2009, 05:32 PM   #7
RZRSHARP_240SX
RZRSHARP_240SX's Avatar
RZRSHARP_240SX is an unknown quantity at this point
they should be reverse thread. I know that you dont want to lean the breaker bar against the frame rail but that is the easiest way to break that bolt loose. all you have to do is tap that starter and its loose.
RZRSHARP_240SX is offline   Reply With Quote
Old 04-01-2009, 07:20 PM   #8
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Okay, here's what you do.
pull fuel pump fuse.
place socket and breakerbar onto crank pulley nut.
leave it in neutral.
close hood/tire into enginebay to absorb the momentum of the breaker bar.
Crank.
Superman that hoe.
SochBAT is offline   Reply With Quote
Old 04-01-2009, 07:56 PM   #9
Folken
Folken's Avatar
wow i'm going to give that a try soooshi, sounds alil safer, worst case i'll have a reason for a new hood
Old 04-01-2009, 10:40 PM   #10
WoolyS14DET
Trader Rating: (18)
Damb...................... coming from a cert. mech. that sounds sketchy as hell !!
Old 04-01-2009, 10:54 PM   #11
PinkPanther
PinkPanther's Avatar
PinkPanther is an unknown quantity at this point
Send a message via AIM to PinkPanther
OP, if you put the car in a higher gear such as 5th with the ebrake pulled the car will be less likely to roll foreward while you are torquing on that crank pulley bolt. If you still cant get the bolt off, put a pipe on the end of your breaker bar and beast that shit.I wouldn't try that cranking the engine method unless you want a breaker bar through your hood or fender and a stripped crank bolt. If all else fails go fend someone with an impact wrench; they work great.
PinkPanther is offline   Reply With Quote
Old 04-02-2009, 12:54 AM   #12
SochBAT
It won't fuck shit up if you've got the right bracing (the breaker bar should be unable to freely move).
I've done it a buncha times.
Old 04-02-2009, 12:56 AM   #13
Razi
Razi is an unknown quantity at this point
Get a breaker bar, a pipe, a hammer and hit the end of the pipe as hard as you can.
Human impact gun y0.
It should break loose.
Razi is offline   Reply With Quote
Old 04-02-2009, 03:57 AM   #14
Folken
Folken's Avatar
sigh.... msg lenght
Old 04-02-2009, 04:02 AM   #15
Folken
Folken's Avatar
Wooly I am a tech, I understand but i'm out of options, I have blue point gun but as I said I don't have air at my place and I can't take my car to work to use there air, and before i pay for 2 secs of labor i'm going to try one of these methods, i'll try 5th gear i didn't know that, if not i'll let you know know which part of the bay my breaker bar landed in
Old 04-02-2009, 04:05 AM   #16
91240sil80
91240sil80's Avatar
91240sil80 is an unknown quantity at this point
we wedged something into the flywheel so it didnt move i think a skrewdriver it took us like 20 mins to get the pulley and something else off that seems hella sketchy but you gotta use what you can you know? lol
need my aim or phone number ask your mom im sure she still has it
91240sil80 is offline   Reply With Quote
Old 04-02-2009, 05:42 AM   #17
SochBAT
WHY are you leaving it in gear? Do you really want your car to jolt at you?!?!
Keep that shit in neutral.
Old 04-02-2009, 06:10 AM   #18
toointoxicated62
toointoxicated62 is an unknown quantity at this point
breaker bar + pipe = done
toointoxicated62 is offline   Reply With Quote
Old 04-02-2009, 04:30 PM   #19
Folken
Folken's Avatar
I've come across a few forums that say put it in gear, and the engines just going to keep turning over if you don't, guy from works letting me use his electric impact gun, and a tech thats been doing it for decades told me to remove the starter and wedge something in the flywheel. I won't try the cranking it unless i run out of options... thanks for your input guys I appreciate it, i'll report back saturday and tell ya which, if any, worked
Old 04-05-2009, 07:16 AM   #20
Folken
Folken's Avatar
okay the answer to my problem.... Electric Snap-on Impact Gun, they may not seem like it but they have the torque to get it off, took less then 2 secs if even
Old 05-27-2009, 03:54 PM   #21
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
SR Rise from the grave.
Glad to hear an electric impact gun worked. I am stuck on the same issue, my bolt wont turn without the whole motor turning. I'm currently waiting on my friend to bring his impact gun.
umm... thats not right is it?
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 05-27-2009, 04:28 PM   #22
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
Put it in 5th gear or highest gear and then use a ratchet with breaker bar.
garagelu is offline   Reply With Quote
