#31 |
![]() Join Date: Jul 2008
Trader Rating: (26)
![]() ![]() Feedback Score: 26 reviews
agreed. i'm just saying that when this happens, a helical acts as an open diff and you can't use the ebrake trick. and before anyone says anything. i know, set up your suspension properly. this is just a hypothetical to make a point.
#33 | |
![]() Join Date: Apr 2003
The only point that I would bring across is that a mega tight stiff suspension in most cases is not needed. Infact if you want to initiate a drift sooner at lower rates of speed you will want to have a much softer suspension. Roughly around a 6/4 spring rate on average and then depending on dampening deal with the spring rates from that point (possibly a 8/6 spring rate, but anything lower is actually much more comfortable for an HLSD to perform). Unless you are a formula drift lisenced pro on a smooth track more than likely will a 2way diff, with a stiff 12/10 or 10/8 spring rate suspension would be needed. On a practicle level most novice amature drifters aren't exceeding crazy 90 MPH speeds in the middle of a drift in which a tight suspension would be needed for higher G forces. Most tracks I go on I'm barely exceeding 65MPH and having a softer suspension has actually been more effective in making cleaner drifts, regardless of the slight body role. A softer suspension I find more effective for touge, mild drifting, auto x, and grip, I tend to like the suspension to utilize it's chassis geometry rather than leaving it so stiff that manuverability has decreased. This is why in most cases an HLSD is better than most diffs on the market, especially for it's price, it's the best bargain. Anyone telling you that a super slammed ,mega tight spring rate is the way to go is a straight jackass poser IMO, and truely hasen't spent time on the track or on the touge. In other words if you know how to build your suspension to your chassis's geometry, a helical for the price kicks serious ass.
#34 |
![]() Join Date: Apr 2007
yeah so i found out my vtc solenoid was unplugged (plug fell off), now as you can imagine my traction issues are magnified... even with brand new 275-40r17's at the top of third it gets squirly...
jeeeezus! i need lsd.... and i'm pretty sure the subframe collars i installed only made it worse (correct?) shoot... they dont even make 305-40r17s, the max i can go is a 285
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER. |
#35 | |
AFC #1
![]() Join Date: Oct 2003
#36 | |
![]() Join Date: Jan 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
クリス |
#37 | ||
OBX LSD for 240sx R200 - Page 2 - HybridZ as far as specialty tools i used an impact wrench to take out the bolts that hold the casing togther but thats it, no presses needed. when you get the diff there are like 9 or 10 bolts that hold the unit together that need to be removed. From there several helical gears that need to be removed surrounding a central gear. Under the central gear are two other straight cut gears that sandwich a set of belleville springs(they look like washers but the center is elevated above the outer edge). Mine were thin and brittle one was cracked and broken. I replaced them with a set of McMaster-Carr belleville springs that are a lot stronger as per the part numbers given to me by Aceinthehole. Its up to you to decide how you wish to stack them.()()()() setups yields the most deflection per load while a ))))))) setup will increase the load ability and minimise deflection. I believe the setup that the obx uses stock is (())(()), iirc i did mine ))(())((. Then its just a matter of putting everything back together. A VERY IMPORTANT NOTE, when reassembling the diff find some kind of stick or something to run through the center of the diff to keep the springs aligned otherwise you might end up with an unpredictable diff. Here are the part numbers for the 2 sets of springs from McMaster-Carr 9712K82 1 Pack High-carbon Steel Belleville Disc Spring, .630" Id, 1.250" Od, .040" Thick 9712K444 1 Pack High-carbon Steel Belleville Disc Spring, .531" Id, 1.250" Od, .062" Thick Hope that helps!
tamscc.org |
#38 |
The obx auction says "Make Sure To Check Backlash When Installing, Shim Properly."
What exactly do you need to shim?
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER. Last edited by opponheimer; 04-16-2009 at 05:32 AM.. |
#39 |
Shims go at each end of the helical and bearings. Believe me you will need more than what is offered in the diff. Backlash is a tolerance that is required between the gear teeth. Too much or too little can be bad.
#40 | |
Maybe we're not talking about the same rears.... OP, go helical. Like you said, you're not drifting or anything so it really doesn't matter but the helical is pretty versitile anyway. When i was in my dsm stage and was registered on 2gnt.com (lame) they had a huge discussion on why replacing $15 worth of washers on an obx was smarter than spending $800 on a quaife. Dunno if this batch they have out now is any better but i've heard that there was no c-clip seating area machined into obx diffs. Some people just didn't run them or cut seats in with a rotary tool of some sort. They may have stepped their game up after all the dsm hate mail they got during a group buy they had a couple years back. |
