Old 04-18-2009, 01:56 PM   #1
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
S13 electrical issue
A good friend of mine has an S13 coupe that's having some electrical issues. He installed a turbo timer (Cause he's got a CA18), and everything was fine and dandy. A few weeks later, the dash lights all started staying on like the key was in the run position, and other electronic components that would work in the run position worked as well (Radio, blinkers, etc.). The car shuts off with the key just fine, however. Last week (about 3 weeks after he started having the problem), he noticed the body harness in the driver's side fender had gotten chewed by the tire, and had 3 wires exposed from their jackets. We figured this was the problem, a short caused by the wires exposed and touching. Well, today I head over there and separate the wires from each other, tape everything up, and ziptie it out of the way to prevent further rubbing, but this didn't solve the problem. Could he have a bad ignition switch? What else should we look for (Without pulling the dash out)?
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
