Old 04-18-2009, 09:53 PM   #1
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
excessive road noise, any ideas?
I just got my new tires put on and the car was just aligned. I noticed that I am hearing a lot of excessive noise coming from the front of the car. When I turn the wheel slightly to the left the noise stops, then when I straighten out it comes back. Any ideas what this could be? At first I thought it could have been 1 wheel was out of alignment, but like I said the car was just aligned. Could it be a wheel bearing?
khilgers is offline   Reply With Quote
Old 04-18-2009, 10:11 PM   #2
Nezahualcoyotl
Nezahualcoyotl's Avatar
Nezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-known
it could be the tires. Sometimes the design of the tread could make noise. My brother got some generals and said that he noticed the sound while on the freeway. What kind of tires did you get?
Nezahualcoyotl is offline   Reply With Quote
Old 04-18-2009, 10:13 PM   #3
S14DB
AFC #1
S14DB's Avatar
Some tires have a anti dry rot coating on them now. Can be noisy. If it lasts more then 20miles I would take it back.
Old 04-18-2009, 10:18 PM   #4
khilgers
It was doing the same thing on my way home from the last drift event, last year. At that time I was running falken RT615s up front. The car was fine on the way to the event, and noisy as hell on the way home. I ended up replacing the tie rods, and outer tie rods ends because I thought that I bent one, which in turn threw the alignment off.
I'm currently running Maxxis MA-Z1 drifts
Old 04-18-2009, 10:20 PM   #5
S14DB
AFC #1
S14DB's Avatar
Oh, so it existed before the tire change?
T/C rods?
Old 04-18-2009, 10:24 PM   #6
khilgers
Correct. If it was a tension rod wouldn't that be noticed when i did the alignment? If I did bend it my caster would have been way off, correct?
Old 04-18-2009, 10:29 PM   #7
S14DB
AFC #1
S14DB's Avatar
T/C Rod is not a factory adjustment. So if it is within the MLB ballpark factory spec they won't touch it.
Did they give you a printout? Mine was 7* one side and 6* the other side and I had to argue with them to pull the one up to 7*.
Old 04-18-2009, 10:33 PM   #8
khilgers
the alignment was not done at a Tires plus type place. It was done by a local that setups most of the auto-x cars around here. He has been doing alignments for a long time. Any way the caster specs are:
Left: 6.8
Right: 6.9
Old 04-18-2009, 10:39 PM   #9
S14DB
AFC #1
S14DB's Avatar
I would go back and talk it over with him if he is at that level. Tell him what happened and what you replaced and have him check the specs again.
How are the Caster/Camber? Tire distances?
Old 04-18-2009, 10:45 PM   #10
khilgers
The tie rods, and outers were the only parts changed on the car prior to the alignment.
The noise is the same when i was running -2 camber, and with my new setup with -3 camber.
Tire distances, can you be a more specific? Not sure what that means exactly.
Old 04-18-2009, 10:55 PM   #11
S14DB
AFC #1
S14DB's Avatar
Sorry I meant Toe.
Distances between the tires. May be listed as Front/Rear Track, Right/Left wheelbase.
Old 04-18-2009, 10:59 PM   #12
khilgers
My first thought was that the toe was way off, but it's not.
Toe Left: .00
Toe Right: .01
Old 04-19-2009, 12:13 AM   #13
lflkajfj12123
sounds like a wheel bearing
does the noise get louder on a dip sounds like your wheel is going to fall off?
maybe a bolt somewhere isn't torque'd enough
shitty situation guess it could be a lot of things
Old 04-19-2009, 08:12 AM   #14
khilgers
if it was a wheel bearing wouldn't it start to make a little noise then progressively get louder?
Old 04-19-2009, 11:38 AM   #15
khilgers
I just got taking it all apart and it looks like it is the wheel bearing. If you compare each side, the passenger side is all nice and clean, and the driver side has black grease all over the nut to the spindle. Shitty part is that is was brand new and was only on the car for the equivelant of 2 years. Man, drifting is hard on vehicles. Time to explain to the wife that I need to spend another $125 on the car.
Am I able to just replace the bearing and NOT the entire hub?
Old 04-19-2009, 04:09 PM   #16
devnull
devnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymore
Yes, it is possible to replace the bearing only.
devnull is offline   Reply With Quote
Old 04-19-2009, 07:12 PM   #17
khilgers
can anyone else clarify that you indeed CAN replace just the bearing WITHOUT having to replace the entire hub?
Old 04-19-2009, 07:17 PM   #18
S14DB
AFC #1
S14DB's Avatar
Yeah you will just need a press. Bearings usually come preinstalled cause it is easier.
Check your spindle for wear also.
Old 04-19-2009, 07:31 PM   #19
khilgers
Sounds good, at least I narrowed down the problem.
Old 04-19-2009, 08:54 PM   #20
lflkajfj12123
cool
glad you found the problem
you can buy new nissan bearings (best choice) and just press them into the hub
Old 04-19-2009, 10:06 PM   #21
98koukile
98koukile's Avatar
98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough
or buy the hubs from nissanparts.cc for $125 and swap a brand new oem unit in. I've found that with -2* my front tires are much louder. This would change when turning because the geometry of the wheel shifts. Performance tires will cause more road noise anyways, I just replaced both front wheel bearings and they were clearly bad and it didn't make my car any quieter
Just talking about cars, one at a time
Horsepower sells cars torque wins races -Shelby
98koukile is offline   Reply With Quote
Old 04-19-2009, 10:35 PM   #22
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
yea my e30 does the same thing when i turn left the noise gets louder and when i turn right it goes away. it is indeed the wheel bearing because a heavier load is applied on the passenger side when turning left.
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
