Old 04-21-2009, 05:00 AM   #1
dongoesby
dongoesby's Avatar
dongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of light
T28 Turbo Line and Restrictor
I've researched and understood the importance of an oil restrictor for our T28. However, I'm still confuse if it is an individual unit that acts as an adaptor in between the turbo line and the turbo?
I've found that a normal T28 turbo line (Circuit Sports) costs around $110, but a stand-alone turbo line (Earls) included restrictor costs almost $60 more. Is this simply an additional restrictor included in the so called "stand-alone" turbo line or something is different? An oil restrictor bascially costs $10, is there any difference? Am I safe to buy an oil restrictor to put onto a turbo line that is not "stand-alone"?
I've tried to email takamotorsports regarding this, but no replies
dongoesby is offline   Reply With Quote
Old 04-21-2009, 05:09 AM   #2
Ghost240
Ghost240's Avatar
Ghost240 is an unknown quantity at this point
From what I understand, the oil restrictor is in the -AN fitting.
Ghost240 is offline   Reply With Quote
Old 04-21-2009, 06:57 AM   #3
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
Full-Race Motorsports
^^ that sir is an oil restrictor
you can also find some here:
http://www.phase2motortrend.com/babeoilretsi.html
and here:
http://www.ilovemyhookerheaders.com/966303ERL.asp
all this info was found with 1 search on zilvia, next time dig a little
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 04-21-2009, 12:41 PM   #4
dongoesby
dongoesby's Avatar
My question is actually not where to find buying restrictor but information about restrictor. I'd like to confirm if buying a regular turbo line plus an oil restrictor seperately is same as buying a "stand-alone" turbo line.
Thanks.
Old 04-21-2009, 12:46 PM   #5
DaPCWiz
DaPCWiz's Avatar
Thanks.
The restrictor is still the same piece whether your buy it separately or as part of a kit. All of those links were given as examples of what a restrictor looks like.
Old 04-21-2009, 12:55 PM   #6
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
i think what the op is asking is:
if you buy a circuit sports kit, is the restrictor built into the an fitting already or do you need a separate one in addition to the kit.
Old 04-21-2009, 01:15 PM   #7
GSXRJJordan
GSXRJJordan's Avatar
Thanks.
Yes it's the same.
The reason most line kits don't come with restrictors is because you use a different size restrictor for journal-bearing vs ball-bearing turbos.
There you go.
Old 04-21-2009, 04:43 PM   #8
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
^ exactly true. Typically BB turbo's have more restriction b/c they need less oil flow. At the opposite, you have a journal bearing, which relies on a thin layer of oil and close tolerances, so they need a higher flow. TAKA lines, which I use, are unrestricted from the factory.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 04-21-2009, 04:46 PM   #9
TeamFRAT
TeamFRAT's Avatar
TeamFRAT is an unknown quantity at this point
Someone told me that Sr's oil pressure is low enough that I would not have to use a restrictor. Can someone add to, or smash this rumor?
TeamFRAT is offline   Reply With Quote
Old 04-21-2009, 04:53 PM   #10
s14unimog
s14unimog's Avatar
Trader Rating: (22)
Depending on the turbo, you MIGHT be able to get away with it. If you have a BB turbo, I wouldn't do it. I've heard some people say that you can get away with no restrictor on a journal bearing, but I wouldn't test it. The reason being is that there is a large spectrum at hand when considering adequate oiling, not so much with OVER oiling. My SR20 runs over 80psi @ ~5k, that is more than enough pressure to push out your seals.
I run a FP 20G on my SR and was told by them that I didn't need a restrictor; I laughed and hung up the phone. I say 1/32" (0.031") for BB and 1/16" (0.063") for journal....
Old 04-21-2009, 06:49 PM   #11
dongoesby
dongoesby's Avatar
Originally Posted by GSXRJJordan View Post
Yes it's the same.
There you go.
thanks, exactly what i wanted to know!
Old 04-22-2009, 04:07 PM   #12
TeamFRAT
TeamFRAT's Avatar
I scored a hell of a deal on a hks 2510 for a $110 bucks off craigslist. I ordered a .03 restrictor. Someone told me on a local fourm that they didnt require it because the sr didnt have alot of pressure. I feel otherwise now considering you got 80psi at 5k.
Old 04-22-2009, 04:28 PM   #13
GSXRJJordan
I agree completely - SR's run just as much pressure as any other motors lol, easily 70psi - you definitely should be using restrictors. Common sizes are listed above (1/32" for BB and 1/16" for conventional).
