Old 04-23-2009, 09:25 PM   #1
slidewaysmn
slidewaysmn's Avatar
slidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really nice
Can faulty ecu cause limp mode, rather than maf?
My s13 redtop swapped in my s14 is stuck in limp mode, and is also not getting a starting priming pulse...could both these problems be caused by the ecu? The MAF is not getting grounded. The maf ground goes to the ecu, which grounds it. Could my ecu be bad? Also why no priming pulse?
'95 Zenki
'85 Cressida
slidewaysmn is offline   Reply With Quote
Old 04-24-2009, 09:30 AM   #2
slidewaysmn
Bump...please.
'95 Zenki
'85 Cressida
Old 04-24-2009, 10:01 AM   #3
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
Its the ecu or wiring up to the ecu is bad... I was shipped a bad ECU and it did the same thing you describe. If you want me to checkout your wiring I can.. but you should def. try another ECU. Take apart your current one and smell for burnt parts.
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 04-24-2009, 10:06 AM   #4
DirtyS14
DirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enough
Is that f**king rupert the bear in your avatar?
S14 240SX aka "The Dirty S14"
fizzerkart.com/s14.html
DirtyS14 is offline   Reply With Quote
Old 04-24-2009, 10:54 AM   #5
GSXRJJordan
GSXRJJordan's Avatar
To answer your question, yes it could cause that, but it's not likely. Make sure you have the ECU grounds connected to the car somewhere (intake manifold is OEM location), and pin 16 on the ECU plug goes to MAF signal, pin 17 to MAF ground.
This should help you out ~
http://www.plxdevices.com/ECUDatabas...0DET_91_95.pdf
Remember, that pinout reads from the back of the plug, not the front.
Old 04-24-2009, 12:55 PM   #6
slidewaysmn
Yeah, i've gone threw all of my grounds a good 3 times. Re-did a few of the chassis grounds because of the newly painted engine bay. I'm trying to borrow an ecu from someone currently....
'95 Zenki
'85 Cressida
Old 04-24-2009, 05:08 PM   #7
shinmei-2006
shinmei-2006 has a little shameless behavior in the past
it could be the MAF, MAF wires to ecu, or ecu drivers for the MAF.
shinmei-2006 is offline   Reply With Quote
Old 04-24-2009, 05:24 PM   #8
GSXRJJordan
Did you do a pin-to-pin on the MAF wires using a continuity tester? Make sure the problem isn't in your harness first... since the fact that you've swapped an SR20 into your car means that you've extended those MAF wires, 99% chance the problem is there.
Also, the MAF signal wire is shielded, and that shield is sometimes grounded - make sure that the shield-wire (silver, tiny strands) doesn't touch the signal wire (copper, larger strands) on the inside.
Old 04-25-2009, 09:11 AM   #9
slidewaysmn
Yeah, the first thing i did was re-check my solders on the portion i used to extend it. I used a shielded wire to extend it also. It may be possible that the metal strands in the shielding are grounding the others....so i'll have to check on that again..
'95 Zenki
'85 Cressida
