Old 04-27-2009, 05:21 PM   #1
tuner92
tuner92's Avatar
tuner92 is on a distinguished road
plug on bottom of fuse box
what is the plug on the bottom of fuse box on the passanger side in the engin compartmet?
i swaped an sr and it wont start its not gettin any fuel i dont see any plugs that will fit in it from the sr harness can that be the reson it wont start
tuner92 is offline   Reply With Quote
Old 04-27-2009, 06:19 PM   #2
projectRDM
projectRDM's Avatar
Wow, good post. Size on plug? Color? Number of pins? Anything remotely helpful?
FORMERLY R240NA
Old 04-27-2009, 06:38 PM   #3
tuner92
tuner92's Avatar
its gray plug and it is on the braket that holds the fues box
and the wires from the plug go right into the fuse box
and from what i can see it has 2 pins and its oval shaped with flat sides
Old 04-27-2009, 07:05 PM   #4
GSXRJJordan
GSXRJJordan's Avatar
There are 6 or 7 plugs on the fuse box - the one you're talking about sounds like E16 on the Engine Room Harness ('EL' section of the FSM), which goes to E203 on the engine lower harness (believe it's an Auto-only plug, but I don't recall what's on it).
Edit: yup, found it - if you've got 2 plugs, should be an auto car without theft warning - only important thing it's got on it is the starter solenoid wire on it, from the auto inhibitor switch (only lets you start in Park or Neutral) - that wire's black and white from the fuse box harness and black/yellow going to the starter. Don't know what the other wire is.
