Old 04-26-2009, 06:53 PM   #1
redx
redx is an unknown quantity at this point
Differential indentification
Have a VLSD diff, confirmed with orange stamp, has 6 bolt axle flanges, and is jdm(as it came in a shipping crate from japan).
What diff is this? Need to buy a kaaz to replace it, its burnt out!
What diff did the PS13 SR20DET come with?
redx is offline   Reply With Quote
Old 04-26-2009, 07:49 PM   #2
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
what do you mean what diff is it? The name of the rear end is r2000v just buy a kazza 1.5 or 2way for a 240sx and put it in.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 04-26-2009, 08:23 PM   #3
fuk240sx
fuk240sx is an unknown quantity at this point
Do you mean the gearing of the diff? I believe it has a 4.36 final drive ratio, also it doesnt matter what diff it is your gonna out a kaaz into it, you can install a kaaz diff into a non lsd pumpkin as well.....
fuk240sx is offline   Reply With Quote
Old 04-26-2009, 08:34 PM   #4
redx
Originally Posted by fuk240sx View Post
Do you mean the gearing of the diff? I believe it has a 4.36 final drive ratio.
Trying to actually figure out what diff it is, since:
Ca equipped cars came with 5 bolt hubs and a VLSD.
sr20det powered cars came with a open diff and 6 bolt hubs.
The diff in question is a VLSD equipped with 6 bolt hubs, which makes me suspicious that it may be a 96-98 180sx diff with a viscous lsd, but i cant confirm. Aswell, it also has the cooling fins which i assume were only for JDM cars, which confirms its JDM.
So what is a 6 bolt flange, VLSD, JDM diff out of?
Old 04-27-2009, 11:38 AM   #5
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
well there's the r200diff and the j30 diff that are a triangular 6 bolt with 2 bolts on each point and then there's the gtr diff that has 6 individual bolts. you can google the rest. since there's no pictures i can't help much more than that.
godsmack is offline   Reply With Quote
Old 04-27-2009, 01:06 PM   #6
LoneStarSilvia
LoneStarSilvia's Avatar
LoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond repute
It came out of any VLSD 240sx. USDM 240's used the 6 bolt, 3x2 pattern. My old stock, OEM VLSD had the same 6 bolt pattern.
IIRC J30 diff's are 5x1 for earlier models and 6x1 for newer ones.
JDM or not, I'm pretty sure its just a regular VLSD
LoneStarSilvia is offline   Reply With Quote
Old 04-27-2009, 01:28 PM   #7
OutToWinPAHC
OutToWinPAHC's Avatar
OutToWinPAHC is an unknown quantity at this point
Send a message via AIM to OutToWinPAHC
Open it up... on the ring gear is a stamped number ration ie 12:47 which is the number of pinion teeth: ring gear teeth. Divide the ring gear teeth by the pinion teeth and there's your drive ratio... ie 47 / 12= 3.916
OutToWinPAHC is offline   Reply With Quote
Old 04-27-2009, 03:53 PM   #8
zstylelowrider
zstylelowrider is an unknown quantity at this point
Since you guys are on the topic of rear ends. Anyone ever swapped a 350z rear end into an s14. I aquired one and from looking at it they appear to almost have the same mounting points. I do know that the axle flanges will have to be changed out and that the axles for the z and the sx are the same. But i would love to park this thing in the back of my car.
zstylelowrider is offline   Reply With Quote
Old 04-28-2009, 05:48 AM   #9
OutToWinPAHC
i've seen people ask that question before and I am curious about the because of the lower ratio. Its also a R200V or open end R200, I don't know of the case is the same, but I wouldn't doubt if you could swap the guy into a J30 case,
Z33 - MT - R200 - 3.538
Z33 - MT - R200V - 3.538
Z33 - AT - R200V - 3.357
Old 04-28-2009, 06:06 AM   #10
yokotavia
yokotavia's Avatar
yokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enough
Send a message via MSN to yokotavia
no.
s13 and 180sx CA's came with a vlsd 5 and 6 bolt.
AND
s13 and 180sx SR20s came with vlsd 5 AND 6 bolt
either way you have a vlsd.
and either way you should throw it away and get a real diff
Banana boat chronicles
yokotavia is offline   Reply With Quote
Old 04-28-2009, 06:09 AM   #11
A31CEFIRO
A31CEFIRO is an unknown quantity at this point
It could be a r180 diff housing its a little smaller than a r200 diff. I had one in my cefiro when i got it. It was from a 180 sx and had 6 bolt axles.
A31CEFIRO is offline   Reply With Quote
