Old 01-25-2002, 04:55 PM   #1
MyFirst240SX
MyFirst240SX is an unknown quantity at this point
My book for my car only shows the PCV for the KA24DE and i have a KA24E.  ANyone want to inlighten me? its not the Hose that connects to the top of the Head to the air intake before the throttle body is it?
thanks
MyFirst240SX is offline   Reply With Quote
Old 01-25-2002, 05:10 PM   #2
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from MyFirst240SX on 4:55 pm on Jan. 25, 2002
yes !
Take the tube off, and you'll see it !
thanks</td></tr></table><span id='postcolor'>
Kid Zelda is offline   Reply With Quote
Old 01-25-2002, 06:04 PM   #3
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
It's the same for E and DE.
S13Grl is offline   Reply With Quote
Old 01-25-2002, 06:11 PM   #4
MyFirst240SX
Are your sure? &nbsp;My book says that the PCV is down in the front a little underneath where the valve cover gasket is. &nbsp;It sasy this is for the KA24DE
Old 01-25-2002, 06:13 PM   #5
Kid Zelda
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from S13Grl on 6<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>4 pm on Jan. 25, 2002
errgggg... wrong, try again !
Old 01-25-2002, 06:17 PM   #6
S13Grl
Married to the Mob
S13Grl's Avatar
It should be on the same location, if I recall correctly.
Old 01-25-2002, 06:19 PM   #7
Kid Zelda
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from S13Grl on 6:17 pm on Jan. 25, 2002
It should be on the same location, if I recall correctly. </td></tr></table><span id='postcolor'>
err, try again !
Old 01-25-2002, 06:30 PM   #8
chickenmanq
chickenmanq is an unknown quantity at this point
Hey, I know where it is. &nbsp;At least, I know where it is on the truck, but it should be the same. &nbsp;Look under the intake manifold, in the most annoying possible place. &nbsp;It should be right near the front of the engine, hidden under the manifold. &nbsp;You can get it from the side with a 17 mm wrench, I think. &nbsp;
chickenmanq is offline   Reply With Quote
Old 01-25-2002, 11:42 PM   #9
MyFirst240SX
Ill check out that tomorow, its 1:31 am. &nbsp;Hmm that sux. &nbsp;SO whats that thing on top of the Head?
Old 01-26-2002, 03:37 PM   #10
chickenmanq
I'm not sure what thing on the head you're referring to. &nbsp;There are all sorts of valves and sensors near the head. &nbsp;Where exactly is this one located?
Old 01-26-2002, 04:33 PM   #11
MyFirst240SX
on the top of the Head Manifold i think its called(the thing that says Nissan 2400 or what ever)on the front left of it. there is a valve or soemthing with a 90ยบ bend towards the throttle body. &nbsp;THe PCV valve is actually on the THrottle Body. &nbsp;I found it today.
Old 01-26-2002, 10:21 PM   #12
chickenmanq
Whoa, wait a minute. &nbsp;PCV valve can't be on the throttle body. &nbsp;PCV is Positive Crankcase Ventilation. &nbsp;The valve that is near your throttle body should be the EGR Exhaust Gas Recirculation, or the Breather filter. &nbsp;A little tube that runs from your valve cover to you air filter box and has a little piece of foam or something in it. &nbsp;Oily. &nbsp;Your PCV valve should be a smallish, 1.5&quot; long metal fitting, with a pressure sensitive spring type deal on one end. &nbsp;Poke a pen in it, and the metal will move. &nbsp;Oh yeah, call Autozone, and they can look up the location of the PCV on their computer for you. &nbsp;IT will tell you right where it is.
Old 04-28-2009, 02:08 AM   #13
miklos
miklos's Avatar
miklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choices
Pcv
Does anyone have a photo of the PCV in an SOHC KA24?
miklos is offline   Reply With Quote
Old 04-28-2009, 07:31 AM   #14
brian m
brian m's Avatar
brian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond repute
Since you want to bump a post from 2002:
Let me google that for you
and give you a pic also:
Originally Posted by Dousan_PG View Post
dont ask if you wont take the advice
god...... some of you guys suck some serious testicallage
brian m is offline   Reply With Quote
