![]() Join Date: Jan 2006
![]() i just recently installed the MAX angle kit. i have s13 tein inners and outers. there doesnt seem to be too much thread left and im scared they will get stripped out eventually. just wondering what inner tie rods have more lengh than the s13 teins?? i have heard z32 and z33 teins are longer?? any info would be great thanks alot.
#7 | |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
You are a genius! I would just use SPL Z33 outers, but only if you're a baller.
![]() Best way to do business with me? Make your best offer FIRST. |
#8 | |
Z32 and Z33 inner tie rods are SHORTER than the S13/S14 ones, so they won't work. Z32 or Z33 outer tie rod ends will not fit the S13/S14 spindles. Our SPL outer tie rod ends will fit the S13/S14 spindles and are longer than the stock S13/S14 outer tie rod ends (that is why they are intended to be used with the shorter Z32/Z33 inners for those with stock knuckles), so they will provide you with the extra thread engagement you need with the modified knuckle. They are a direct fit with your Tein inners, so you won't need to change the inners. |
both will thread into the steering jack, but the threads for the outer tie rods are different between the two. Most aftermarket outer tie rods use the s14 thread pitch.
![]() Join Date: Oct 2010
so, sorry for bringing this 4month old topic back up but...if I buy my step bro's Tien S14 inners...and got OEM S14 outers...then the S14 inner would fit the rack, the s14 inner and s14 outers will fit each other, and the S14 outers will fit into my S13 OEM knuckle...am I correct??
