Old 05-27-2009, 04:52 PM   #1
Este510
Este510 will become famous soon enoughEste510 will become famous soon enoughEste510 will become famous soon enoughEste510 will become famous soon enoughEste510 will become famous soon enough
SR red top, no spark on cylinder #2
I recently change the wiring harness on my s13 with a sr20, and now I have no spark on cylinder #2. The wire is blue w/yellow stipe I believe it goes to the ecu.
So my question is what am I looking for?
Este510 is offline   Reply With Quote
Old 05-27-2009, 06:36 PM   #2
johngriff
johngriff's Avatar
Use a VOM to test for connectivity from the ecu plug through the harness, ignitor, then to coil packs.
[email protected]
Old 05-28-2009, 08:02 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You tried swapping spark plugs and coilpack around to eliminate them out of the possibility?
CLICK HERE!!!
Old 05-28-2009, 10:00 AM   #4
Teambadrun
Teambadrun's Avatar
Teambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to all
check that you are using the correct ecu to the correct loom. sometimes some SR20 ECUs have differnt pinouts for coilpacks...
cylinder 1
cylinder 2
C 3
C4
should be
pin 1
pin 2
pin 8
pin 9
dont qoute me thou
havnt done this in a LONG time
Teambadrun is offline   Reply With Quote
Old 05-28-2009, 10:07 AM   #5
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
definatelly check the coils by switching a known good one with the one that wont fire, that way youll know if its the coil or your wiring. then if its in the wiring check the wiring from the ignitor to the coils and from the ecu to the ignitor. i have seen ignitors go bad, but still work on 3 cylinders. so basically the wiring was good the coils were good but the ignitor was not working for one cylinder properly
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 05-28-2009, 03:30 PM   #6
Este510
The ignitor was not working for one cylinder, Thanks!!!!!!!
