Old 05-29-2009, 05:48 PM   #1
RichK14
RichK14 is an unknown quantity at this point
350z 18" on S13
1993 Nissan 240SX Hatch
KA24DE, 5spd
KYB Struts
I recently did the 5 lug and z32 brake swap on my s13.
S14 FLCAs/spindles/hubs
Z32 Front and rear calipers/rotors
Z32 Rear hubs
I also acquired a set of wheels from a buddies totaled '05 350z. Theyre the 18" touring wheels.
When the install was complete, i noticed i had some alignment issues. The front wheels were extremely toed out and the camber was a bit out of whack.
I took it to a local shop to get aligned and this is what it looks like now:
FL
Camber -2.5
Caster 5.7
Toe .04
FR
Camber -2.5
Caster 5.1
Toe .04
RL
Camber -.8
Toe .15
RR
Camber -1
Toe .16
With that said, i know ill need aftermarket support to get the numbers within my personal specs.
I've encountered another problem though. When i turn the wheel completely left or right, the bottom spring seat on the strut turns and hits (closes the gap between the tire/strut) the top edge of my tire. Does anyone have any experience with this problem? I can take pics if need be.
-RK
RichK14 is offline   Reply With Quote
Old 05-30-2009, 01:01 AM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
if i'm understanding what you're saying, then you could probably get away with adding a 5mm slip on spacer and that would resolve the issue.
