Old 06-18-2009, 05:21 AM   #1
youngbrazee1
youngbrazee1 has made poor choicesyoungbrazee1 has made poor choicesyoungbrazee1 has made poor choicesyoungbrazee1 has made poor choicesyoungbrazee1 has made poor choicesyoungbrazee1 has made poor choices
boost question
is there a way to manipulate the boost with out a boost controller?
youngbrazee1 is offline   Reply With Quote
Old 06-18-2009, 05:23 AM   #2
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
Adjustable actuator.
HYPNOTIK is offline   Reply With Quote
Old 06-18-2009, 09:24 AM   #3
Tensor187x
Tensor187x has a little shameless behavior in the past
Yup. HKS Actuator.
Tensor187x is offline   Reply With Quote
Old 06-18-2009, 09:43 AM   #4
slider2828
slider2828's Avatar
Screw in screw out. Make the actuator rod longer = more boost, shorter rod actuator = less boost....
Turn and Burn!
Old 06-18-2009, 11:26 AM   #5
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
^^^Isnt it the other way around??? Longer rod = less boost and shorter rod = more boost??? Or atleast thats how it is with my hks actuator, i think.
bl3ujay07 is offline   Reply With Quote
Old 06-18-2009, 01:05 PM   #6
slider2828
slider2828's Avatar
I think the way I describe it is correct as the longer rod holds the wastegate closed for longer... I am logically guessing....
Turn and Burn!
Old 06-18-2009, 01:15 PM   #7
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
you can also use a restrictor from advace, it looks like a normal plastic vac tuve union but it has a metal restricter inside of it. that will raise the boost. and if its too high you use a drill bit to ream it out by hand a little. its ghetto but it works
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 06-18-2009, 01:25 PM   #8
johngriff
johngriff's Avatar
space the wastegate against the bracket w/washers
[email protected]
Old 06-18-2009, 01:35 PM   #9
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
but the rod pushes the flap outward, opening the wastegate
the shorter the rod, the more the spring has to be compressed to open it as much?
thats how i understood it, ive only played with a couple hks internal gates, i can never remember
ILoveJDM is offline   Reply With Quote
Old 06-18-2009, 03:40 PM   #10
slider2828
slider2828's Avatar
O crap you are right, its the opposite, forgot its a pull not a push!
SHORTER IT IS!!!
Turn and Burn!
Old 06-18-2009, 07:00 PM   #11
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
correct the shorter the rod the more boost you get. hks actuators are pretty cheap but i'd also get a boost gauge while you're at it. you have to adjust the hks and you don't want to be boosting to high with stock injectors if thats what you have.
godsmack is offline   Reply With Quote
Old 06-18-2009, 07:21 PM   #12
slider2828
slider2828's Avatar
Yeah 1/4 turn at one time!
Turn and Burn!
Old 06-22-2009, 09:59 AM   #13
youngbrazee1
i already have a boost gauge and 740cc injectors... so how do i shorten the rod...by cutting?
Old 06-22-2009, 10:06 AM   #14
Razi
Razi is an unknown quantity at this point
Or by putting washers against the wastegate brackets as Johngriff said.
Or by getting a HKS wastegate
You could cut it and weld it if you want I guess.
Razi is offline   Reply With Quote
Old 06-22-2009, 10:08 AM   #15
HYPNOTIK
HYPNOTIK's Avatar
Yes, get out the hacksaw. LOL
Are you serious? HKS ADJUSTABLE actuator, you turn the rod to lenghen or shorten it.
Old 06-22-2009, 10:41 AM   #16
Ashtony
Ashtony is an unknown quantity at this point
just the answers i was looking for. thanks guys
Ashtony is offline   Reply With Quote
