![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
hate it,love it whatever build
A little background. i got the car back in 2001ish, from the shop i use to work at. condition was decent, just a shell, no main harness, front end, engine or trans. sorry no pics digi cameras were too expensive n shitty at the time.
i had some shitty taste at the time lol. and i have some beat up ass fenders lol ![]() then i got a decent front end. but still had a shitty bumper ![]() then i finally got a stock silvia bumper on for a while ![]() then the 5-lug and stock s-14 wheels ![]() and some coil-overs Tein Flex ![]() motor was a stock red top with usual bolt ons ![]() drove it around for a while, and the gas tank developed a leak, so as a temporary fix i used some jbweld. It worked for a while until i started to get more leaks, so i decided to bite the bullett and buy a new tank. while the car was out of commission i bought some rims. Stern Beastface ![]() 17x8 +32 from and 17x9 +38. but i didnt end up using them and got a good deal on some Motegi Touge's 18x9 +12 and 18 x 10 +30 ![]() ![]() ![]() so then i was like eh screw it and bought a kit n threw on some fender flares ![]() ![]() ![]() ![]() i was also wanted to clean up the engine bay and add some shit ![]() then more changes bc i was bored. lol ![]() ![]() decided to spend more money and build a lot of SS lines ![]() little bit of wire tuck ![]() ![]() figured i would paint the stock IM before ![]() after ![]() then i hated the routing of the heater hoses so i did this ![]() ![]()
#3 | |
then it was time to get the oil cooler set up. got a Greddy Oil filter base with Thermostat, and an oil cooler from a Volvo ![]() ![]() picked up and S-15 turbo to replace the worn out t25 ![]() added a -10 drain fitting ![]() and to fix the fact that i cut the heater hose routing i needed to make a water return ![]() ![]() ![]() for the Fuel system i did AN lines bc i hate rubber fuel hose. and non of that clamp a SS line to stock hard line. lol ![]() ![]() now for whatever reason i decided that i would take the motor out and prep the car for paint and shit ![]() ![]() ![]() ![]() ![]() door jams primered ![]() ![]() also since im usually bored and my social life kinda sucks at the moment i cleaned up the sub frame and added some spacers and cleaned and painted the underside of the rear ![]() ![]()
Motor is out so im like fuck it. might as well re-fresh it a bit and add some more parts
![]() ![]() took the motor apart and found this shit ![]() this is the #3 cam cap and mating surface ![]() here is the cam ![]() instead of trying to repair this i decided to get another head got it like this ![]() sent it to a machine shop and had it surfaced and hot tanked, and it came out like this ![]() ![]() the block wasnt in bad condition eithor ![]() ![]() mostly a lot of build up on the pistons ![]() so i sent it to a buddy of mine and he checked it out, and re-ringed it, and did all new bearings, thrust washers, and honed the bores got it back like this ![]() ![]() bought a new tool ![]() so i could put on these ![]() bc springs, retainers, and cams. ![]() then i got all new rockers b/c the stock ones were pretty scored up ![]()
so im supper inspired about some of the wiring job that are here on Zilvia,
so i cleaned up my engine harness ![]() ![]() added that braided sleeving...looks all purdy lol ![]() for the oiling system i used the Tomei block adapter ![]() now it mates up nicely with the greddy filter adapter. i also didnt like the banjo bolt for the turbo oil feed line so i got this from Pegasus ![]() now that every thing was apart i wanted to check the tranny to make sure it was in good condition, it was dirty as shit ![]() ![]() took the casing apart to inspect all the gears n synchros ![]() ![]() ![]() ![]() everything lookd pretty good and i never had a problem with it. since it was all apart i decided to paint the housing, but i had to clean it up ![]() dont ask y b/c i dont know but i went with john deere green ![]() ![]() now it was time to start cleaning up and get my motor back togather ![]() got an Apexi 1.1 HG ![]() and ARP studs ![]() figured i would color coordinate some shit ![]() ![]() then for whatever reason again, i got a differnt turbo, Gt2871 with .82 AR T3 flange and a top mount manifold from JGS tools ![]() ![]()
started to work on the bay, kinda shitty pic of it partially painted
![]() and i also got the kit primed ![]() ![]() the complet mod list so far is this Motor re-ringed, and new bearings, thrust washers. new water pump and oil pump/front cover new timining chain kit, tensioner guides etc. BC 264 cams, Ti Retainers,Springs Apexi 1.1 Hg, and Power FC new rocker arms CS rocker arm stoppers all new gasket set. Greddy oil pan, filter relocation base, Air expansion tank, oil catch can, turbo timer, Profec E-01 Boost controller, and MSS Koyo rad with sard 1.5 cap Trick flow fuel filter all Braided SS lines for oil and fuel. HKS SSQV egay FMIC volvo oil cooler custom fan shroud with 12" puller fan PE belts. GT2871 turbo JGS manifold modified fuel rail for AN lines Sard FPR Q45 fuel pump. Greddy IM (just got it in the mail) AEM wide-band Espiler JGT-500 cat-back test pipe megan dp custom tubo outlet pipe with V-band clamps. Exterior origin aggressive kit origin roof spoiler flares silvia s13 front Suspension/Brakes Tein Flex coilovers 5-lug S14 FLCA Sub-frame spacers z32 brakes front and rear with q45 e-brake and 2+2 cables. 180sx brake booster z32 master Greddy FSB Cusco RSB w/V-bar Tein EDFC (just got it, in the mail) Wheels Motegi Touge 18x9 +12 front 18x10 +30 rear with spacer = -2 offset those will be changed once i find some baller rims interior. eastbear copy seats working DCC 180sx cluster with HUD wired in. KPH on cluster and MPH on HUD Kazama Shift Knob. i still need to get injectors, cam gears, some seals for the tranny. re-do the dash in suade, and a waste gate. and here is how she looks at the end of the day lol ![]() i just injured my back so i really cant work on it too much...hopefully i will be able to get more done next week. Comments.
#12 | ||
anyways. here is the tranny all put togather ![]() then i figured WTF and painted the engine cross member, tranny mount, and front tension bracket gay purple. ![]() ![]() here are some shots of the engine bay all painted and cleared, the color is cast coat iron ![]() ![]() ![]() i just got this thing in the mail...... one more thing to mount lol ![]() here are some shots of the motor all mocked up and ready to go in. ![]() ![]() ![]()
#15 |
![]() Join Date: Jun 2009
looks like the only thing you didnt paint was the valve cover which just so happens to be in need of a repaint from the looks of that rub spot....lol
seriously sweet build. |
