Old 07-09-2009, 07:47 PM   #1
jing
jing's Avatar
jing is an unknown quantity at this point
Battery / relocation questions
My new 240 has had the stock battery relocated to the back, battery tray and all with NO box. From my understanding, this is very unsafe as a conventional battery will release hydrogen gasses inside the driving compartment (since it's in the trunk) unless it is in a sealed box with a breather tube.
I visited a local shop today that specializes in battery's and was going to buy a marine box and run a tube from that through the outside of my car. However, the salesperson there advised me that this was a bad idea, and gave me 2 other options. The 1st option was to buy a conventional battery ($100 + tax) that was in some special case with 2-built in holes in the top that are designed for breather tubes. The 2nd option was to buy a special "AGM" battery that would cost $250. AGM's as I was told, do not emit any gasses as they are made up of one solid mass.
Is it safe to run a marine box and not have gasses releasing everywhere?
or..
Do I have to buy the battery mentioned in the 1st option?
jing is offline   Reply With Quote
Old 07-09-2009, 08:26 PM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
I would go with Numba one
s13 @ fullboost is offline   Reply With Quote
Old 07-09-2009, 08:44 PM   #3
gijoe69
gijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant future
Send a message via AIM to gijoe69
Run a 0/1GA from Engine Bay to a Fuse to the trunk with a secure battery box so ACID don't eat shiet up in your trunk haha
gijoe69 is offline   Reply With Quote
Old 07-09-2009, 08:44 PM   #4
jivetoast
jivetoast is an unknown quantity at this point
Send a message via AIM to jivetoast
well here is what i did, buy a really small battery from tirerack.com. we were originally going to do the marine box, but it was too much of a pain to mount the box in the back. the marine box WILL seal and shouldnt emit gasses but there will be a build up of gas in the box.
jivetoast is offline   Reply With Quote
Old 07-10-2009, 01:58 AM   #5
JAY_AHR
JAY_AHR is an unknown quantity at this point
i got mine in the trunk, a lil bigger than the stock one so it gives it enough juice to run the long of a wire and start the car.. and i also went to autozone and grab a battery cover and drill a hole right on the side just for the hydrogen gasses or if in any case the battery over flow with acid for some reason.
then plug that hole with a hose and ran it just inside the passenger side panel and out thru the vent underneath the quarterpanel.
JAY_AHR is offline   Reply With Quote
Old 07-10-2009, 02:13 AM   #6
S14DB
AFC #1
S14DB's Avatar
Get a sealed battery box and use the hose to vent out the car. Sales guy was trying to sell you crap. You still need a box for most tech inspections. May need a external cut off too.
Old 07-10-2009, 04:35 AM   #7
gotspins13
gotspins13's Avatar
gotspins13 is an unknown quantity at this point
Send a message via Yahoo to gotspins13
orrr
you can just get a dry cell
perfectly said! FJ20ET 16 valve - the holy grail of Nissan engines
gotspins13 is offline   Reply With Quote
