Old 07-09-2009, 08:01 PM   #1
Giebs
Giebs is an unknown quantity at this point
need toe rods?
so i lowered my car and my rear camber is maxed out at -2.9*, my rear toe is ok and not maxed out. i want to bring camber back a little more positive (probably less than -2.0*) with new arms. how likely is it that i will run out of toe adjustment and need to buy new toe arms also?
Giebs is offline   Reply With Quote
Old 07-09-2009, 08:16 PM   #2
jr_ss
Camber correction shouldn't affect toe in/out much if at all. I would assume you'd be ok with the arms you have now. Toe wasn't affected when you lowered it and went super neg camber right? It should be the same way when you return camber back to "stock" specs.
Old 07-09-2009, 11:12 PM   #3
discosteak
discosteak's Avatar
discosteak is an unknown quantity at this point
wrong i would buy toe rods, correcting camber on lowered 240's toes out the rear bad
discosteak is offline   Reply With Quote
