Old 07-10-2009, 12:14 AM   #1
Tensor187x
Tensor187x has a little shameless behavior in the past
gauges replace climate control
Hey guys, im thinking of doing the aftermarket guagues were the climate control goes, and moving my climate control elsewhere.
I've searched around here on zilvia and couldn't really land a good post.
Trying to find a place that sells a kit for doing this kind of thing? I'm thinking of getting 3 gauges installed there.
Any help would be greatly appreciated.
Tensor187x is offline   Reply With Quote
Old 07-10-2009, 12:23 AM   #2
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
I made my own piece out of fiberglass.
I don't have a picture right now, but I'll try and remember to post one up tomorrow.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 07-10-2009, 09:28 AM   #3
Tensor187x
Try and get some pictures up!
I want to see.
Old 07-10-2009, 10:14 AM   #4
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
it's custom. measure. get material. cut to size. trim holes for drop-in installation of gauges.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 07-10-2009, 10:16 AM   #5
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
EDIT: this is only for S13s
i took out the center vent and got a triple 60MM gauge bezel to go in there.
it's a piece of aluminum with 3 holes. i got it off ebay.
keep your climate control at least for heat broseph, but there really is no need for the center vent on our cars.
clark is offline   Reply With Quote
Old 07-10-2009, 10:18 AM   #6
99maxgtr
99maxgtr's Avatar
Trader Rating: (22)
99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices
Feedback Score: 22 reviews
that is only for s13's unless that's what the op has.
You're 16. You barely know what kind of girls you like.
99maxgtr is offline   Reply With Quote
Old 07-10-2009, 10:31 AM   #7
clark
clark's Avatar
ah good call. i always assume people have s13s
edited my post
Old 07-10-2009, 07:00 PM   #8
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
I'm not quite sure there is a kit for replacing the climate control. I mean you can put a gauge cluster in there but you will most likely need to extend the wiring harness to the climate controller to re-locate elsewhere.
I have a S14 and re-located my climate control into the arm rest.
Maiku240sxS14 is offline   Reply With Quote
Old 07-10-2009, 08:45 PM   #9
Rittmeister
Rittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really nice
How did you extend the cable(s)? Or does the S14 climate control not have cables for the mix door?
E36 M3 - new project
1990 240SR - screamed down the road
Rittmeister is offline   Reply With Quote
Old 07-10-2009, 09:03 PM   #10
ZilviaKid
ZilviaKid's Avatar
ZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the rough
just run more wire?
2004 Nissan 350z
2002 Nissan Silvia
ZilviaKid is offline   Reply With Quote
Old 07-10-2009, 09:12 PM   #11
Andrew Bohan
can't run more wire to make mechanical cables longer
Old 07-10-2009, 09:40 PM   #12
BustedS13
BustedS13's Avatar
stop trying to be mister fancy and cram three gauges in your unused DIN space.
Old 07-11-2009, 01:05 AM   #13
Maiku240sxS14
Trader Rating: (37)
No you have to extended the wire harness (meaning add more wire to each wire), if I recall there are about 32 wire that need to be extended.
You still have to cut the actual DIN to get gauges in there. Plus I was eventually going to delete the radio and put more gauges or switches.
Old 07-11-2009, 01:51 AM   #14
JohnC
JohnC's Avatar
JohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of light
my solution
and CC goes into the din slot, just need a dremel to enlarge the din slightly.
JY Racing LTD.
JohnC is offline   Reply With Quote
Old 07-11-2009, 01:42 PM   #15
BustedS13
BustedS13's Avatar
no you don't. i had two gauges in mine, and you can fit three.
Old 07-11-2009, 09:31 PM   #16
timlush
timlush's Avatar
timlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to behold
Send a message via AIM to timlush
S14 is all electric. There is no mechanical cable.
timlush is offline   Reply With Quote
Old 07-11-2009, 09:32 PM   #17
Kouki_Love
Kouki_Love's Avatar
Kouki_Love is an unknown quantity at this point
Originally Posted by JohnC View Post
my solution
do you have any pics of it on the car?? looks good!!!
Kouki_Love is offline   Reply With Quote
Old 07-11-2009, 09:50 PM   #18
99maxgtr
99maxgtr's Avatar
Trader Rating: (22)
i want one. put me on the list.
thanks.
Old 07-12-2009, 09:50 AM   #19
JohnC
JohnC's Avatar
will snap a few tomorrow.
JY Racing LTD.
Old 07-14-2009, 04:02 AM   #20
JohnC
JohnC's Avatar
Bad Picture but you get the idea,
JY Racing LTD.
