Old 08-01-2003, 07:34 PM   #1
Swoop411
Swoop411's Avatar
Swoop411 is an unknown quantity at this point
Send a message via Yahoo to Swoop411
Suspension Gurus I need advice!
Sed ut perspiciatis unde omnis iste natus error sit voluptatem accusantium doloremque laudantium, totam rem aperiam, eaque ipsa quae ab illo inventore veritatis et quasi architecto beatae vitae dicta sunt explicabo. Nemo enim ipsam voluptatem quia voluptas sit aspernatur aut odit aut fugit, sed quia consequuntur magni dolores eos qui ratione voluptatem sequi nesciunt. Neque porro quisquam est, qui dolorem ipsum quia dolor sit amet, consectetur, adipisci velit, sed quia non numquam eius modi tempora incidunt ut labore et dolore magnam aliquam quaerat voluptatem. Ut enim ad minima veniam, quis nostrum exercitationem ullam corporis suscipit laboriosam, nisi ut aliquid ex ea commodi consequatur? Quis autem vel eum iure reprehenderit qui in ea voluptate velit esse quam nihil molestiae consequatur, vel illum qui dolorem eum fugiat quo voluptas nulla pariatur?
Swoop411 is offline   Reply With Quote
Old 08-02-2003, 01:48 AM   #2
thx247
thx247 is an unknown quantity at this point
shoot i forget what the rough idle is caused by....I would check anything related to the air intake tract. Make sure there are no leaks.
The shimmy is probably the wheels or tires. If you goto a decent alignment shop, they can balance the tires and fix any alignment problems you may have.
thx247 is offline   Reply With Quote
Old 08-02-2003, 05:49 AM   #3
chineseb0i
chineseb0i's Avatar
chineseb0i is an unknown quantity at this point
Send a message via AIM to chineseb0i
i second agree on the tires as far as the shimmying. I've had some crappy *** improperly warn down tires and had them on the front of one of my 240s and it shimmed and caused the steering wheel to move side to side like crazy. Another possibility are the bushings. If you're going at somewhat high speeds, the tc rod bushings may be what you want to replace. Even if it's not that, it's always good to get new ones. www.pdm-racing.com sells them for a good decent price and there have been good reviews on them since they provide a faster response. that's all i can think of as far as the shimmy. As for the idle, maybe the idle needs to be readjusted or air flow or something. Getting a new fuel filter might help since the old one might be somewhat clogged. Getting a good fuel injector cleaner or fuel system might help too if the fuel injectors are clogged. Rough idle is usally caused by lack of air and/or fuel mixture so something to do with the fuel or air system might need fixing or cleaning. Good luck. Hope my info helped somewhat.
89 240sx Coupe
chineseb0i is offline   Reply With Quote
Old 08-02-2003, 08:39 AM   #4
Swoop411
Swoop411's Avatar
Old 08-02-2003, 09:20 AM   #5
cdlong
Originally posted by Swoop411
In the mornings after the car has sit for a while its hard to start but after I drive it around all day it fires right up....I am at a loss here!
sounds like a power drain. they are a pain in the *** to fix, first you have to find it. when your car is going to sit for a while, pull some of the fuses. when the car starts up fine that's the circuit the drain is on. finding it from there is a challenge.
cdlong is offline   Reply With Quote
Old 08-02-2003, 11:25 AM   #6
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
Shimmy> Make sure wheels and tires are in *excellent* condition, the less wheel weights the better. This means having the balancing done at a quality place and making sure they understand how sensative the car is to balancing. The S13 is extremely sensative to balancing issues. Plus, the 89-90 had a replacement spring you could install in the steering rack: 48237-10V02. I installed this spring and it basically cured my 55 mph steering wheel shimmy. I warn you now though, that shimmy could also be caused by warped brake rotors. So, you really have to look at the entire system and cleanup issues while you go.
Idle> Its probably the AIV or EGR. The AIV is easy to clean and disassemble.. do that first, its usually the culprit.
- Mike
old_s13 is offline   Reply With Quote
Old 08-02-2003, 02:00 PM   #7
adey
adey's Avatar
adey is an unknown quantity at this point
re: your idle... if none of the above (more common) fixes solves the idle... you may have a grounding problem somewhere. check/clean/tighten all the grounds that you can find, and it may help some. Or just get a grounding kit.
Good luck!
adey is offline   Reply With Quote
Old 08-02-2003, 02:42 PM   #8
Swoop411
Swoop411's Avatar
Old 08-03-2003, 12:49 AM   #9
chineseb0i
chineseb0i's Avatar
i'm sure i can say on behalf of everyone You're Welcome. We're a growing community of nissan enthusiast trying to help each other out with problems. I've received a lot of helpful tips and info from the more experienced people out there yet have given back to the less experienced as well. I hope my clutch install write up will be of use to many of you. I spent a lot of time writing it..West will be posting it sometime soon so look for it and tell me what you think.
Solomon
89 240sx Coupe
