Old 07-22-2009, 04:08 PM   #1
nrmskate
nrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura about
Check out my Knock Sensor Wiring *PIX*
Well, ive had a few other threads that have helped diagnose the problem. A lot of people have been saying it's almost never the KS itself, so check the wiring, I checked the sub harness wiring, checked out good, but, I checked the wires from the ECU that plug into the sub harness, and there was some bear wire.
Do you think this is the problem?
nrmskate is offline   Reply With Quote
Old 07-22-2009, 04:12 PM   #2
nrmskate
In case you couldn't see.
http://i196.photobucket.com/albums/a...1067EDITED.jpg
Old 07-22-2009, 04:21 PM   #3
daisy_is_sweet
daisy_is_sweet's Avatar
daisy_is_sweet is an unknown quantity at this point
Perhapzzz...
daisy_is_sweet is offline   Reply With Quote
Old 07-22-2009, 04:27 PM   #4
nrmskate
How do I know that the wire in the shielded wiring isn't melted also?
And is it shielded all the way down to the ECU?
Old 07-22-2009, 04:49 PM   #5
nismolism
nismolism's Avatar
nismolism is an unknown quantity at this point
you need to test the continuity..lol i dont think i spelled that right...hahaha
no wire that goes to any thing should be bare wire..
nismolism is offline   Reply With Quote
Old 07-22-2009, 04:57 PM   #6
nrmskate
I checked the OHM reading on the signal wire, and it was 200ohms, but on the other hand, it get's no volts.
Which stumpts me.
If it's not getting any volt readings does that mean that there is a short somewhere before the plug?
Old 07-22-2009, 05:50 PM   #7
nrmskate
Im also stumped on this part (kinda)
When I reset my ECU, and basically replace the resistor with the Knock Sensor, it only gives my code 34
But, if I have it just plugged into the Knock Sensor, I get codes 12 (MAF) and 34 (Knock Sensor)
Im confused.
I really think it may be shorted out somewhere, and I have no clue on how to fix it.
Old 07-22-2009, 06:04 PM   #8
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
make new lines or get a new one
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 07-22-2009, 06:11 PM   #9
nrmskate
How do I know it's the line though?
and how would I go about re-wiring it?
Where can I find a diagram of a KA24DE ECU Pinout?
