Old 08-04-2003, 06:20 PM   #1
BuudWeizErr
BuudWeizErr's Avatar
BuudWeizErr is an unknown quantity at this point
Send a message via AIM to BuudWeizErr
Car won't shut off
Just installed my Koyo and my Black Magic fan and now my car won't shut off... grr.
I don't know if it's because of the fan or if my wiring got messed up when I was working on it.
Heres the deal. With my old fan and radiator, the fan had 2 wires, + and -, that's it. So I used a Radio Shack ignition relay so that it would run when the car was running. That relay had +12in, +12out, ignition in and ground out.
Now, with the black magic, the ignition relay is built-in. So, I hooked up +12, +12 with a circuit breaker, ground and ignition (or switched).
Now my car starts and runs beautifully, extra now with that weight off the water pump, but now it won't shut off.
HELP!
Extra Info:
89 Hatch, Redtop SR, wiring done by phase2.
1989 Nissan 240SX, SR20DET
sillbeer.COM : phase2motortrend : Garage Works
BuudWeizErr is offline   Reply With Quote
Old 08-04-2003, 06:34 PM   #2
radrex88
radrex88's Avatar
radrex88 is an unknown quantity at this point
Did the thing not come with instructions, you would think it did If you got it brand new. Sorry, just had to ask, I wish I could see a picture of what it looks like, Im more of a visual person.
Signature exceeds 400x200 picture size limits set by the User Agreement.
radrex88 is offline   Reply With Quote
Old 08-04-2003, 06:43 PM   #3
BuudWeizErr
Here are the instructions
http://www.flex-a-lite.com/auto/instructions/150.pdf
Old 08-04-2003, 07:25 PM   #4
BuudWeizErr
Now the car won't start at all.
My clock is on, the seatbelts move, go to start it and nothing.
Old 08-04-2003, 08:15 PM   #5
misnomer
misnomer's Avatar
Trippy
Disconnect the fan, see what that does for you.
Old 08-04-2003, 08:40 PM   #6
radrex88
radrex88's Avatar
Im just as confused as you, I cant see that you did anything wrong, the only thing I can think of is that you had a short in the wiring somewhere and it blew a fuse. Just check all the fuses and wiring for shorts.
Old 08-04-2003, 08:43 PM   #7
BuudWeizErr
It does nothing.
I have everything apart now. Just going to tow it to phase2 I guess.
Probably going to pick up a battery relocation kit on the way there and get my battery out of the engine bay. Who knows what the problem up there is.
As I'm sure most SR people with GReddy/Blitz/HKS FMIC kits with batteries still in the bay will agree, there is no room up there to work which sucks, major. As well as it being a ROYAL PITA to hook up the terminals too.
Hell, for all I know it was just the terminals being loose, but I don't know for sure, so whatever.
Old 08-04-2003, 11:00 PM   #8
radrex88
radrex88's Avatar
Sorry I couldnt be more help, hope you get her fixed in a hurry.
Old 08-05-2003, 08:15 AM   #9
MarvynDT
MarvynDT is an unknown quantity at this point
I believe you initially wired the relay to the new fan incorrectly if your car won't shut off. That is a common effect when incorrectly wiring a relay to your 12+ switched ignition.
Now you say your car won't start? Do you hear any clicking sounds from the engine bay? You probably blew a fuse or a broken relay.
MarvynDT is offline   Reply With Quote
