Old 08-05-2003, 01:06 PM   #1
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
My N1 dual smells....
Ive had this problem since i got it a year ago and never went away. Apparently its smells like burning of some sort and really gets irritating. Is there something that needs to be replaced, fixed to get rid of that smell? When i was passing my friend flooring it he said that when he had his window down he could smell the exhaust. My car is in real good condition and couldnt be spitting out black smoke cause my car is a 1996 240sx with 35000 miles on it. Any help will be great
SilviaSR20DET is offline   Reply With Quote
Old 08-05-2003, 02:51 PM   #2
SiDeWaYs S150sx
SiDeWaYs S150sx is an unknown quantity at this point
is it touching your bumper?? it could be melting it
SiDeWaYs S150sx is offline   Reply With Quote
Old 08-05-2003, 02:58 PM   #3
hookedup240
hookedup240's Avatar
hookedup240 is an unknown quantity at this point
Send a message via AIM to hookedup240
did you take off your cat? What does it smell like?
hookedup240 is offline   Reply With Quote
Old 08-05-2003, 03:01 PM   #4
SilviaSR20DET
Its not melting my bumper i know for sure because its not even touching my bumper. The smell is weird, its smells like burning rubber or clutch or something like that. And no i didnt remove the cat for this exhaust. I have heard lots of complaints about the smell that the n1 single and duals produce so i guess its supposed to happen. It only smells when ive been driving hard like flooring it and stuff.
Old 08-05-2003, 05:20 PM   #5
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
mine smelled funny when i first got it (Blitz) but now it doesnt have that smell. its kinda like a break-in smell u know how it burns the insulation stuff.
how long have u had the exhaust?
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 08-05-2003, 05:29 PM   #6
SilviaSR20DET
Ive had this exhaust for a year now and still has this smell coming out so it probably not run hard enough or something. Could it be like the o2 sensor?
Old 08-05-2003, 06:58 PM   #7
drift into a curb
drift into a curb's Avatar
drift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond repute
Are you sure it's your exhaust then. You said it smells like rubber, you sure it's not your clutch? You sure you aren't riding the clutch when you're driving you're car hard? I dunno, anything other than a gas/carbon monoxide smell kinda throws me off to believe it's something else.
drift into a curb is offline   Reply With Quote
Old 08-06-2003, 12:48 AM   #8
knightrider
knightrider's Avatar
knightrider is an unknown quantity at this point
it could be burning the underside of your car, i just got a st may shotgun and it touches the underside of the car sumtimes and its burning the undercoating off my car, i need to wrap it in header wrap, just too lazy. but it does have a weird smell only at high rpm, my guess is from the high exhaust temps.
Drift_ Into A Mountain
Jim Wolf Technology
Stock CA18DET-SR T25-greddy FMIC-JWT SR Lightened FLywheel-300zxTTclutch-SR20DET JWT tuned Ecu
knightrider is offline   Reply With Quote
Old 08-06-2003, 02:06 PM   #9
SilviaSR20DET
Ya i think its because of the high temprature because it only smells like burning when im in the high rpm and doesnt smell when cruising. So it must be the exhaust itself for sure. Any way to fix this problem or do i have to stick with it?
Old 08-06-2003, 08:22 PM   #10
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Get your exhaust pipes coated with ceramic coating or heat wrap and see if it stops. Thats my guess. Also, for some reason I could swear I remember someone saying that when your cat goes bad it stinks really bad. Can anyone confirm this?
-m
mbmbmb23 is offline   Reply With Quote
Old 08-07-2003, 12:49 AM   #11
Angelus
Angelus has a brilliant futureAngelus has a brilliant futureAngelus has a brilliant futureAngelus has a brilliant futureAngelus has a brilliant futureAngelus has a brilliant futureAngelus has a brilliant futureAngelus has a brilliant futureAngelus has a brilliant futureAngelus has a brilliant futureAngelus has a brilliant future
I think it`s the "undercar rust protection" which is melting by the extrem high temperatures of the N1Dual when you drive hard...
A friend of me have got exact the same problem with the HKS Super Dragger.
Are you happy with your Apexi N1 Dual otherwise? Maybe I will order the same exhaust..
Angelus is offline   Reply With Quote
Old 08-07-2003, 11:22 AM   #12
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
Check to see if there's a leak at the gasket. The way the N1 dual hangs, it kind of puts a lot of force on the cat and if you don't support it properly when you install it, it can feel tight, though the flanges aren't properly lined up and just a few degrees out of parallel is probably enough to create a small leak that would be right under where you sit.
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 08-07-2003, 01:32 PM   #13
SilviaSR20DET
Ya i think your right about the rust because i spot some rust in between the exhaust connections. I think the rust are coming from the gasket which probably is the thing that caused the burning smell. Oh and ya i love the n1 dual it is the nicest exhaust you can buy for the 240. Sounds great and performs very well in my opinion.
Old 08-07-2003, 06:08 PM   #14
knightrider
exhaust smell, and burning smell is diferent, also if your cat is going bad, it will smell like rotten eggs. and it will smell all the time, not just under high rpm. plus i run a s14 dummy cat, so no innards. its prolly just undercoating.
Jim Wolf Technology
