Old 07-27-2009, 10:01 PM   #1
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
magnetic shielding harness wires??
where do you get magnetic shielding for your wiring harness when doing splices? I've checked online but dont want to spend 30 bucks per square foot on a 50 sq ft roll. i just need a little bit. any help is nice thanks.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 07-27-2009, 10:24 PM   #2
Homer_Simpson
Homer_Simpson's Avatar
Homer_Simpson is on the path to ruinHomer_Simpson is on the path to ruinHomer_Simpson is on the path to ruin
I've seen people using the shielded wires from Home Depot for their harness. I bought mine from here
Belden 6300FE 18/2 Shielded Plenum.
Homer_Simpson is offline   Reply With Quote
Old 07-27-2009, 10:26 PM   #3
burnsauto
burnsauto's Avatar
i have a few old hacked up harnesses. I can send you some if you want (for free, i'll even do the shipping - cause i always liked ya.)
Old 07-27-2009, 10:38 PM   #4
Homer_Simpson
If you're doing the MAFS, knock, TPS etc, the shielded wires from the cannibalized KA harness is perfect since they're all at the perfect length already.
Old 07-27-2009, 10:48 PM   #5
SoguRacing
SoguRacing's Avatar
actually, that reminds me i have a junk yard around the corner that i can get harness from.
Old 07-27-2009, 10:51 PM   #6
Propaganda
Propaganda's Avatar
Propaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enough
I just stripped some old wires lying around and wrapped it around teh needed wires and done
Propaganda is offline   Reply With Quote
Old 07-27-2009, 11:01 PM   #7
SoguRacing
SoguRacing's Avatar
that was my thought about the junk yard.
Old 07-28-2009, 12:25 PM   #8
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
well, doesnt the sheilded wiring have to be grounded, and doesnt the sheilding have to cover 100% of the wire?
Bigsyke is offline   Reply With Quote
Old 07-28-2009, 12:39 PM   #9
RurouniMidnight
RurouniMidnight's Avatar
RurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to all
you can buy it at Frys electonics, or any other electronics stores.
http://nightparade.wordpress.com/
Join in on instagram @nightparade
RurouniMidnight is offline   Reply With Quote
