Old 07-30-2009, 06:05 PM   #1
stunnaben
stunnaben is an unknown quantity at this point
Car is misfiring now that it is back together. Any ideas why. Video included.
I can't figure out why my car is misfiring like crazy. Finally got it back together and now it is misfiring like CRAZY. Here is a vid. Anyone have any ideas
Video - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
stunnaben is offline   Reply With Quote
Old 07-30-2009, 06:38 PM   #2
stunnaben
bump i need help
Old 07-30-2009, 07:01 PM   #3
stunnaben
Anyone anything?
Old 07-30-2009, 07:29 PM   #4
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Have you tried fixing your timing?
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 07-30-2009, 07:33 PM   #5
josephin510
josephin510's Avatar
josephin510 is an unknown quantity at this point
Originally Posted by stunnaben View Post
Anyone anything?
DUDE you smell that. Do your timing
Trade my Rb25 for some wheels.
Buy my Sc300.
josephin510 is offline   Reply With Quote
Old 07-30-2009, 07:33 PM   #6
stunnaben
Well the I can't adjust timing now it won't start.
Old 07-30-2009, 07:33 PM   #7
Okinawandrifter87
Trader Rating: (22)
Also have you tried checking your ignition spark etc? Spark plugs, wireset, making sure that your wires are in the right firing order and not plugged up to the wrong plugs? Just suggestions for you my friend since you havent given us any clues to what youve done to fix or diagnose this. Might wanna help us so we can help you..
Driftphreak87
Old 07-30-2009, 07:35 PM   #8
Okinawandrifter87
Trader Rating: (22)
You dont need your car to start to adjust the timing. Adjusting your timing to the right settings will help you start your car.
Driftphreak87
Old 07-30-2009, 07:48 PM   #9
stunnaben
Alright how do i adjust the timing without starting the car? I've tried adjusting the timing. It was running but now it is not. I've checked spark. It has spark and they are in the correct firing order. Car is getting fuel. Seems like i can give it gas and it'll die and when i let off it's like it gets the gas then. I think it's running a tad rich. I'm ka-t running JWT ecu with 50lb msd injectors and cobra maf. Had to swap engine harness's. One plug is off the car... not sure where it goes. I'll post up a pic
This one here it is one the main engine harness. Right after where it comes out of the firewall it splits off from the big bundle. There are like 4 plugs on this split off. Maybe more maybe less. Anyway this one is unplugged. Also it has no rear 02 sensor. so that plug is not hooked up. Not sure if that affects it or not.
Old 07-30-2009, 07:54 PM   #10
josephin510
Take of the valve cover. 27mm crank pulley bolt turn until the dark chain links line up with the holes on the cam sprockets.
Buy my Sc300.
Old 07-30-2009, 08:24 PM   #11
Okinawandrifter87
Trader Rating: (22)
Wait so you have a ka-t setup? What is your setup?
Driftphreak87
Old 07-30-2009, 08:39 PM   #12
stunnaben
JWT ecu, DSM BOV, Tial wastegate, Turbonetics t3/t4, MSD 50lob, Cobra maf.
Old 07-30-2009, 09:18 PM   #13
stunnaben
I need help you guys lol
Old 08-01-2009, 09:25 AM   #14
stunnaben
Ok so the car is running a little better now. I think i have a faulty msd injector. Anyone have a set of MSD 50#'s they want to part with?
Old 08-01-2009, 01:09 PM   #15
stunnaben
I hooked up my wide band today it was reading 21.8 and 21.9. Max reading is 21.9. Leads me to believe that I have a faulty injector and one of the cylinders is pumping air into the exhaust.
