Old 07-27-2009, 12:02 PM   #1
warauto
warauto is on the path to ruinwarauto is on the path to ruin
s14 Altima fans and clutch fan
I was wondering if the altima fans would fit and be more efficient running with the stock clutch fan.
I know that the altima fans are pullers, Is the clutch fan a puller too ?
I an not running a koyo rad yet, i have the stock sr radiator.
My goal is to make my car run cool as a whistle in the hot south fl temperatures....without dishing out $200 dollars on a koyo and another $100 on moshimoto electric fans....
Right now im running 50/50 coolant, water wetter and a higher pressure radiator cap.
I am going to install a air diverter to maximize air driven through the radiator.
warauto is offline   Reply With Quote
Old 07-27-2009, 12:57 PM   #2
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
I would keep the clutch fan if I were you.
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline   Reply With Quote
Old 07-27-2009, 01:36 PM   #3
Souljahzs13
Trader Rating: (66)
Souljahzs13 is an unknown quantity at this point
Feedback Score: 66 reviews
I did the Altima electric fan conversion, and it works fine. The clutch fan feels like it pulls more air. You will have mod the Altima fan shroud to fit in the bay, cause its a little too wide and it hits the battery tray
Souljahzs13 is offline   Reply With Quote
Old 07-27-2009, 01:51 PM   #4
BustedS13
BustedS13's Avatar
3.8l taurus fan is a beast
also Moshimoto only makes ZX tires.
Old 07-27-2009, 02:04 PM   #5
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
damn you need to search. Stock fan shroud and clutch fans work the best. Unless you dont have the space anymore and your forced to use electrical fans.
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 07-27-2009, 02:11 PM   #6
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
+1243254352345 i just replaced my tarues fan with the oem clutch fan and shroud, its so much better.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 07-27-2009, 07:26 PM   #7
warauto
I wanted to see if running 2 sets of fans would see significant gains in cooling. If i run the stock clutch fan and electric fans, wouldnt that be better hypothetically speaking.....If i could get it to work i think it should be very efficient....
Old 07-28-2009, 01:40 AM   #8
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
just go with alti fans lol tarus fans uses to much amps plus its a single fan what happens if that fan take a sh!t on you?? dual fans FTMFW!!!!
S-Nation S13 is offline   Reply With Quote
Old 08-03-2009, 02:22 PM   #9
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Just use the clutch fan. You can put a little electric fan too for being in traffic. Clutch fan + electric = best of both worlds.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 08-03-2009, 05:57 PM   #10
projectRDM
projectRDM's Avatar
The car already has an electric fan.
For everyone who can't read, (everyone who replied), the OP is asking to add the Altima fans to augment the existing clutch fan. In other words, remove the OE single shroud and electric fan and replace it with the Altima fans and shroud, but keep the clutch fan in place.
So, now that we're clear, yes and no. The Altima fans would move more air than the single electric fan that comes stock, but by removing the OE shroud the clutch fan's airflow isn't directed as well. So you will see improved cooling when the electric fans kick on with the A/C engaged or when the car reaches 203 degrees, but you will loose some efficiency without the shroud in place.
In other words, leave it. The hassle of modifying the Altima shroud and wiring harness the correct way isn't worth the gains at all, unless you make some sort of auxiliary shroud for the clutch fan too.
FORMERLY R240NA
Old 08-03-2009, 06:22 PM   #11
singlecamslam
Yea i know it has the ac fan, i dont have AC and using an s14 ac fan infront of the clutch fan with shroud in place. I think thats a pretty good set up.
Old 08-04-2009, 01:03 PM   #12
warauto
That was a very imformative answer, and It surely helped how you stessed my question in order to get the point across. After reading many cooling posts, I realized that the shroud plays an integral part in clutch fan cooling.
Without the shroud the clutch fan wouldn't be as efficient.
To optimize cooling I built an AIR DIVERTER. IF anyone wants to see pictures i would be more than happy to post some. Thanks
Old 08-04-2009, 01:11 PM   #13
nismoskyz
nismoskyz's Avatar
nismoskyz is an unknown quantity at this point
I'd like to see some pics of this AIR DIVERTER of yours.
Thanks
(function)(form)^(-1)
nismoskyz is offline   Reply With Quote
Old 08-04-2009, 10:29 PM   #14
240 GTR
240 GTR is an unknown quantity at this point
i just installed a set of altima's on my sr'd s13 to replace the clutch fan with no shroud. i understand that the shroud plays a large part in the efficiency of the clutch fan. my reasoning for using the altima fans is that, when wired and setup correctly, they will operate just like oem, but with the ability to adjust when they activate. if they can keep an altima cool, then why wouldnt it work for my car? my car definitely runs cooler now than it did before. i could keep the temp at or under 170* all day if i wanted, even in 90*+ ambient temps
240 GTR is offline   Reply With Quote
Old 08-05-2009, 12:38 PM   #15
projectRDM
projectRDM's Avatar
They definitely do the job, no denying it. On a FWD car there's no way to use a clutch type fan, so they have to come up with an efficient way of duplicating that.
A clutch fan will always move more air though, period. And even if it fails it will still move air, whereas the electric fans failing means you're fucked. I just worked on an NX2000 this morning that was overheating, the fan trigger had burned up somewhere in the car. I rigged it to a ground so at least they'll run and keep the engine from cooking. A clutch fan wouldn't allow that to happen.
But to get back to it, A proper shroud over the clutch fan and properly installed/wired Altima fans together would be a very nice setup for cooling. Both fans wired through relays to trigger on low and high speeds as well as A/C engagement and the clutch fan working all the time would be awesome.
FORMERLY R240NA
Old 08-05-2009, 07:25 PM   #16
warauto
air diverter
Thanks
I will post them as soon as i can.
Old 08-05-2009, 07:40 PM   #17
clay9110
clay9110's Avatar
clay9110 is an unknown quantity at this point
would keeping the cluch fan and tehn adding a pusher fan in front of the radiator work?
clay9110 is offline   Reply With Quote
Old 08-05-2009, 10:02 PM   #18
singlecamslam
I dont see why not, i'm running a puller infront of my clutch fan just for sitting in traffic mostly.
Old 08-06-2009, 08:12 AM   #19
warauto
For highway driving that would be non-essential but maybe it could help out in stop and go traffic..
Moving at high speeds push a whole lot more air than a pusher fan can even dream of pushing....
Old 09-03-2009, 10:28 PM   #20
ono
ono is an unknown quantity at this point
i have taurus fans!! PM me
ono is offline   Reply With Quote
Old 09-04-2009, 12:39 AM   #21
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
Clutch fan FTW seriously, Its been proven many times believe me i research ALOT when it comes to EVERYTHING haha and decided to go with the stock fan setup, I bought all brand new oem stuff from nissan japan, Instead of doing an FAL-345 setup with a DFI Fan controller. Just go with the clutch fan for sure!
om3ga is offline   Reply With Quote
Old 09-04-2009, 06:50 AM   #22
red240
red240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the rough
I live in central Fl. I have an s14 sr with a/c and use the altima fans
I don't have the factory a/c fan and drive it every day no problem
red240 is offline   Reply With Quote
Old 09-04-2009, 01:58 PM   #23
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
I dont think my altima fans have come on in the past 6 months. Maybe its because I have a nismo thermostat, massive radiator, cooling panel and a swirl tank and honda type II.
OP dump the water wetter, it kills the OATs in your cooling system in a few months (BITOG.com for reference). Im about to remove my altima fans due to frying a relay from soldering. I may just go back to the single OE electric fan, even in traffic I can still flip on the fan because ive grounded cooling fan relay #1 to a switch.
Bigsyke is offline   Reply With Quote
Old 09-08-2009, 10:24 AM   #24
warauto
Do you free up any horses when you switch to electric fans, seen as the oem clutch fan causes parasitic stress on the engine ?
Old 09-08-2009, 10:24 AM   #25
warauto
Is it even worth the gains ?
Old 09-08-2009, 03:48 PM   #26
RacerX1
RacerX1's Avatar
RacerX1 is an unknown quantity at this point
Ebay, I picked up a new radiator/e-fan/shroud for $200 and havent had a problem
Waiting to have my Username Fixed.
RacerX1 is offline   Reply With Quote
