Old 08-06-2009, 02:04 AM   #1
monkey7
monkey7's Avatar
monkey7 is making a name for him/her selfmonkey7 is making a name for him/her self
i can disconnect all injectors and car still runs?!
i recently got a fuel rail with injectors and swapped mine out as i thought one of my injectors might be clogged. when i go to start my car it runs real rough like 3 cylinders are firing. but the wierd thing is i can disconnect all 4 injectors and the car still runs! could my fuel regulator be bad? or can most of my injectors be all stuck open?
monkey7 is offline   Reply With Quote
Old 08-06-2009, 02:25 AM   #2
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
mine started to act up too.
my car sounds like a subaru.
and when i accel it sputters.
and its not my injectors either,
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 08-06-2009, 02:27 AM   #3
I LUV MY S13
I LUV MY S13's Avatar
dude have u checked ur codes yet??!?
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 08-06-2009, 03:05 AM   #4
junbugs13
junbugs13's Avatar
junbugs13 is an unknown quantity at this point
did you replace all the seals on the injectors inside the rail cuz it might have a leak just enought to keep the car runnin i had that same prob. but mine was way worst.
junbugs13 is offline   Reply With Quote
Old 08-06-2009, 03:14 AM   #5
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
haven't used a computer on it
lol
- Hong
Old 08-06-2009, 03:20 AM   #6
junbugs13
junbugs13's Avatar
put the rail off the motor but leave the fuel liines on it and turn the car on so it primes the car and see if fuel come anywhere else besides the center of the injector if so you found yur prob. and replace all seals on the injectors all four cuz if one is bad all of them will go bad soon
Old 08-06-2009, 03:46 AM   #7
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
like this ? YouTube - The Magic SR
My sr did that too a while back
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline   Reply With Quote
Old 08-06-2009, 06:44 AM   #8
xpertsnowcarver
xpertsnowcarver's Avatar
Trader Rating: (44)
xpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud of
Feedback Score: 44 reviews
Hahaha! Fuel injector leaks up the butt man.. Why would you disconnect the fuel injector harness and run the motor anyway?? Look up your FSM. The diagnostic is 5th grade level easy to read. Have some patients and read it. You'll see.
Injectors can't get stuck open unless current is constantly flowing through it. I'm sure your FPR is fine. You did make sure to reconnect the vacuum line that belongs to it, right?
My YouTube Channel
xpertsnowcarver is offline   Reply With Quote
Old 08-06-2009, 04:42 PM   #9
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
i would vote just bad seals... autozone sells new o rings for cheap may as well try that first... after you run the car and turn it off will it start again? i had a leaky injector and it would flood my cylinder and the car wouldn't start for a while unless i unplugged it and cranked the car a few times... then i would fire up and die once it ran out of fuel in the rail.. then i would plug in all 4 injectors and it would fire right up...
Tantwoforty is offline   Reply With Quote
Old 08-22-2009, 01:18 AM   #10
punk138
punk138's Avatar
punk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond repute
i have the same problem with cylinders 3 and 4.
im running on only cylinders 1 and 2.
i get spark to all 4
and 3 and 4 are both flooded with fuel.
when i disconnect cylinder 1 or 2 pigtail the engine dies.
but when i disconnect cylinder 3 or 4 nothing changes...
WTF?!?!?!!?
someone please help!!!
ps i bought new fuel filter, injector o ring kit, new spark plugs, new wires, and fresh tune up and great compression to all four due to piston ring swap....oh and new MAF and new timing chain kit...
yes we still roll fenders
punk138 is offline   Reply With Quote
Old 08-22-2009, 03:41 AM   #11
blackrms13
blackrms13's Avatar
lol
take out the ECU and check it
dont need any computer/tools
well a ratchet and a flat head screw driver...
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 08-22-2009, 08:50 AM   #12
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
to be honest the sounding like a subaru topic has been covered if its not your injectors and you positive it isnt then check the seals on the them those fail to!!! havin the injector not fire cause its soaked with gas will give the same affect as if it was a malfuntioning injector!!
BUT DAMN HOW THE HELL DO YOU RUN A CAR WITHOUT INJECTORS?? OR HAVING THEM DISCONNECTED??
S-Nation S13 is offline   Reply With Quote
Old 08-22-2009, 09:37 AM   #13
Dousan_PG
Dousan_PG's Avatar
seriously?
fuel pump is still on
there for fuel is still going thru the rail and thru the injectors.
Aaron
Pink GodziRa
Old 08-24-2009, 12:15 PM   #14
punk138
punk138's Avatar
found the problem.
my cam broke in half!! fml
i was running on two cylinders...how the fuck do you break a cam? ive never messed with it, its the original cam from the motor when i bought the car back in 07!
