Old 08-09-2009, 08:52 PM   #1
lilaznjeff
lilaznjeff's Avatar
lilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to behold
240sx s13 sr20de s15 spec S
i have a complete wiring harness which was converted to s13, will for sr20de s14/s15 late year and early year.
plug and play. for sr20de s14/s15 will work for sr20det converting in to NA motor
ecu 1 completely stock
ecu 2 intake, header, test pipe, exhaust, no fuel cut, (no speedo)
everything works on my car. no problem.
harness is wired tuck and super clean. (no joke) below are picture of the harness in my car !!!
temp sensor, speedo, everything fuction on dash.
1 harness and 2 ecu
300
sr20de distrubutor with wire 80 (cap and rotor is good as well)
sr20de SPLITFIRE wires 100
sr20de spec s maf will work with sr20det s14/s15 better air flow. 80
lilaznjeff is offline   Reply With Quote
Old 08-09-2009, 08:52 PM   #2
lilaznjeff
lilaznjeff's Avatar
shipping will be additonal depending on state and area code
thanks for looking again
Old 08-18-2009, 11:35 AM   #3
brainfood
brainfood's Avatar
Trader Rating: (18)
brainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond repute
Feedback Score: 18 reviews
Is the motorset for sale or just the harness and ecu's?
Bryan Rogers
http://www.seriousbadass.com
brainfood is offline   Reply With Quote
Old 08-20-2009, 12:48 PM   #4
lilaznjeff
lilaznjeff's Avatar
this is JUSt the harness only,
no motor set
Old 03-07-2011, 03:31 AM   #5
Joe415
Joe415 is an unknown quantity at this point
got a question for u lilaznjeff i think i just picked up your old engine would you happen to still have power steering pump also did you run any vacuum lines
Joe415 is offline   Reply With Quote
