Old 09-09-2009, 10:34 PM   #1
BadazzSr20
BadazzSr20 is an unknown quantity at this point
Oh DAMN! That SR20det Is At It Again!!!!
ok guys,
so i just upgraded my turbo from the stock turbo to my nice t3/t4 50 trim turbo. well for you all that dont no i when to the track with a stock sr20det untuned and ran a 13.7 @ 100 on spiking 10psi and settleing 7psi.
so after i did my upgrade i wanted to see what i could do with it not spking anymore. keep in mine im still untuned!! sr20det with a 50trim trubo upgrade!!!
im guessing 225whp to 230whp i dont no forsure its not tuned and has never been dynoed. this is what happen injoy!!!
YouTube - Pat's 240SX 9lbs!!
BadazzSr20 is offline   Reply With Quote
Old 09-10-2009, 12:13 AM   #2
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
So you're still running less than stock boost... Cool. Should have run A LOT faster, BRO.
Old 09-10-2009, 12:26 AM   #3
whiteknightsS13
whiteknightsS13's Avatar
Trader Rating: (-1)
whiteknightsS13 is an unknown quantity at this point
Feedback Score: -1 reviews
x2.............
whiteknightsS13 is offline   Reply With Quote
Old 09-10-2009, 09:10 AM   #4
BadazzSr20
well im running full dirft setup on stock street tires. if i had drags and a real drang setup then im sure i would run 12`s but for what im working with im very happy with my times.
Old 09-10-2009, 09:37 AM   #5
S14_Kouki
S14_Kouki's Avatar
S14_Kouki can only hope to improve
Why are you running at 9lb's you can atleast turn it up to 18 psi. When I first got my s14 with a stock s15 engine street tires I did a 13.4 at 18psi.
S14_Kouki is offline   Reply With Quote
Old 09-10-2009, 11:39 AM   #6
BadazzSr20
Im running a t3t4 50 trim turbo. On 9psi I can't run any higher till i get a tune. it took u 18psi to run a 13.4 It took me 9psi and i ran 13.5. I ran half ur boost and got a tenth slower. Once I get my tune I'll up my boost. my a/f is at 11.5 under woot once I hit higher rpms it goes to 12.5 so 9psi 13.5 that's really good.
Old 09-10-2009, 11:43 AM   #7
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
nice, 50 trim t3/t4 is a good turbo =]
spooled240 is offline   Reply With Quote
Old 09-10-2009, 12:03 PM   #8
mr.booie
mr.booie's Avatar
mr.booie is an unknown quantity at this point
your launch on the 13.5 run seemed to be the best. awsome vid and good job representing.
http://zilvia.net/f/image.php?type=sigpic&userid=70890&dateline=122764  6693
mr.booie is offline   Reply With Quote
Old 09-10-2009, 02:58 PM   #9
BadazzSr20
thank you very much im very happy with it im hoping to get tuned this monday!!! im shoting for 300whp for now and i want to change my setup for more drag base. anyone have any idea on what i would need to get my car to cut 1.6 60". right now my best on street tires is 2.0 and i do that almost every pass. this drift setup is killing me.
Old 09-10-2009, 03:24 PM   #10
chibo
chibo's Avatar
chibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfection
Send a message via AIM to chibo
Less than stock boost on a non stock turbo, nice comparison. Quit posting shit like this.
Nice job, OP
1989 S13 | 1996 S14 | 2001 E46 | 2009 ZX6R
chibo is offline   Reply With Quote
Old 09-10-2009, 09:50 PM   #11
ILoveMyRHS13
Trader Rating: (25)
Nice job, OP
Why the fuck would you run less than stock boost on a BIGGER turbo?
Old 09-10-2009, 10:00 PM   #12
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
im not sure if your joking or not but a bigger turbo will push more air, and anything higher then 9 psi on his t3/t4 will put his air fuel ratios into an unsafe setting. So until he gets a tune hes running a safe 9 psi
Black240Ct is offline   Reply With Quote
Old 09-10-2009, 10:20 PM   #13
S13Boosts
S13Boosts's Avatar
S13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfection
lol WEAK /
S13Boosts is offline   Reply With Quote
Old 09-10-2009, 11:46 PM   #14
Z33dori
Z33dori's Avatar
dougy there is this thing called tuning...
add bigger turbo ... and up the boosty... motor goes boomy
to the OP... do you even have anything to tune teh car on (SAFC doesn't count)
if not i would recommend you just go back to t28 and run like 10psi and get the same times...
I know what you are dealing with tho. My buddy has hatch S14 sr, ported&polished head, BC 264 cams springs and retainers, cometic HG and ARP studs..... stock 28 7psi goes 13.7 at 106 spinning all over the place.... FPR tune too boot... oh and that was on 195/50 econo-junk tire
