Old 09-15-2009, 01:39 AM   #1
konan83
konan83 is an unknown quantity at this point
collapsed radiator hose
what can cause the upper radiator hose to callapsed, its a brand new hose. also its been running hot. 91 240sx
konan83 is offline   Reply With Quote
Old 09-15-2009, 10:32 AM   #2
blackrms13
blackrms13's Avatar
exactly like u mentioned, overheating
look into it before u blow the HG
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 09-15-2009, 10:36 AM   #3
murda-c
murda-c's Avatar
your return hose from the overflow might be clogged, or you may have a bad radiator cap, which doesn't relieve the vacuum in the system once it cools down.
the collapsed hose may be whats causing it to overheat.
Old 09-15-2009, 11:34 AM   #4
S14_Kouki
S14_Kouki's Avatar
S14_Kouki can only hope to improve
Or the thermostat could be stuck closed
S14_Kouki is offline   Reply With Quote
Old 09-15-2009, 11:44 AM   #5
Ceepo
Ceepo's Avatar
Go thru and check your thermostate, headgasket, and cooling system in general and see whats causing it to "run hot"...
Old 09-15-2009, 01:20 PM   #6
jorge1190
jorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to all
my car did this not too long ago ended up being the thermostat.
jorge1190 is offline   Reply With Quote
Old 09-15-2009, 01:43 PM   #7
S14_Kouki
S14_Kouki's Avatar
Im telling you replace that thermostat
