Old 09-15-2009, 08:11 AM   #1
driftertim
driftertim's Avatar
driftertim is a well-known jackass
Send a message via AIM to driftertim Send a message via MSN to driftertim
SR Power FC Issues Early Black top or later gen?
I'm Having some problems deciding what type of Power FC i should buy, because when i got the engine it came with an ECU I dont remember what ECU because the ECU was stolen from me last year when I took it off to send to enthalpy for a tune along with my Toyota 4Runner.
So my questions are :
Do I buy a red top PFC I found at a great deal " used "?
will the commander work with the engine I have if its for a red top and I buy a red top PFC ?
I'm also doing a wire tuck but without cutting too many things, I'm extending the headlights/flashers/ CAS/ MAF/ a few other things but soldering them properly and heat shrinking etc...
Do I have an Early Black Top SR20 Engine or later gen 1996.8 and up?
I have a GT2860RS Real Garrett turbo with Z32 MAF
Should I buy a new unit for my blacktop with L-Jetro?
Should I buy a new unit for my blacktop with D-Jetro? What are the advantages of going MAF-Less? I know if I pop a coupling I'll make it home...
Does the D-Jetro give idling issues and use more fuel? Is it older technology?
Any other possible things that can cause the problems.. ?
I got the VIN # from the front clip my motor came from : HEre are details.
TYPE : E-RPS13
Chasis # : RPS13-323048
Model : RPS13JFTG50
Color Trim : 32b G
Engine : SR20 (DET ) 1998 cc
Trans Axle : FS5W71C RC40
Plant : X
Thanks,
Tim Tadayon
FRIENDS DONT LET FRIENDS DRIVE STOCK
1992 Coupe SE
driftertim is offline   Reply With Quote
Old 09-15-2009, 12:48 PM   #2
slociv
slociv is an unknown quantity at this point
Send a message via AIM to slociv
You can use the red top ecu on a black top. The only major difference between a red and black is the actual tune in the ecu, and since your replacing it with the PFC it doesn't matter. The biggest advantage to a MAP based unit is the fact you are not limited by a MAF or have to worry about a MAF going bad. I prefer the MAP based unit, but you should also talk to your tuner, they may prefer one over the other which could get you a better end result.
slociv is offline   Reply With Quote
