Old 09-22-2009, 10:57 PM   #1
s14kouki44
s14kouki44 is a name known to alls14kouki44 is a name known to alls14kouki44 is a name known to alls14kouki44 is a name known to alls14kouki44 is a name known to alls14kouki44 is a name known to alls14kouki44 is a name known to alls14kouki44 is a name known to alls14kouki44 is a name known to alls14kouki44 is a name known to alls14kouki44 is a name known to all
s13 Brakes don't fit!!
I upgraded to a z32 30mm caliper using a 350z track rotor and they don't fit under my work xd9's. 17" z33 stock wheels can fit them but the barrel of the xd9 is just a tad too small. It rubs ever so slightly.
So my question is if it would be ok to file down the higher points of the caliper to make it fit? Or if I should just sell the wheels and get a new set? If that's the case, does anyone know what aftermarket (work,ssr,volk) in a 17" that will work with this brake setup? I really don't want 18's on my s13
s14kouki44 is offline   Reply With Quote
Old 09-22-2009, 11:02 PM   #2
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
Get sum spacers
WoolyS14DET is offline   Reply With Quote
Old 09-22-2009, 11:03 PM   #3
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
Get like a tiny 3mm spacer. They DO sell them.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 09-22-2009, 11:07 PM   #4
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
yea get some spacers. they even have em at pepboys now. ahah
Slammed Assassin is offline   Reply With Quote
Old 09-22-2009, 11:08 PM   #5
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
Spacer would be best if you can fit the tires under the fender the way you want. Otherwise plenty of people grind down the Nissan logo on the outside of the caliper. Your choice
96Turbo is offline   Reply With Quote
Old 09-22-2009, 11:08 PM   #6
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
yea what they said
http://squarespokes.com/
besTint is offline   Reply With Quote
Old 09-22-2009, 11:23 PM   #7
96Turbo
96Turbo's Avatar
wait a minute...are you saying that the actual BARREL rubs the caliper? (inside of wheel to outside of caliper)??? Because I was assuming you mean that the front of the caliper was rubbing the inside of your spokes.
If it's not the spokes rubbing then you have bigger problems...Maybe need 18"s or something with a different barrel design in 17"
Old 09-22-2009, 11:29 PM   #8
s14kouki44
No no no. The spokes are a-ok have nice concave with hella clearence. The top of the caliper rubs on the inside of the wheel...the barrel. Maybe 1.5mm too tall to tuck in there. I can fit the wheel on but the grinds on the inside of the wheel. I love my works and Id hate to sell em
Old 09-22-2009, 11:37 PM   #9
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
man that sucks. I guess you have two choices. Grind down on the caliper. If shouldn't affect the caliper other than cosmetics as long as its not too much. Or get rid of the spacer and big rotor and go back to stock 300zx rotor.
Or third choice....buy different wheels. Those xd-9's must be have a weird barrel design. I know for sure evo/sti rotors are either same size or a little bigger than 350z track rotors. I fit my sti brembos with quite a bit of room still left on my fn01r-c.
garagelu is offline   Reply With Quote
Old 09-22-2009, 11:37 PM   #10
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
get 3-5mm spacers and you'll be ok. the spacers should bring the rims out so that it wont touch the barrel no more. happens to me all the time when i'm switching rims around. i have to change spacers on depends on the rims i put on.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 09-23-2009, 12:15 AM   #11
96Turbo
96Turbo's Avatar
is the shape of the barrel such that it would help to move the wheel out a little (as in spacers)?? Or is it a constant size near the caliper?
If it's really only 1mm or so, I think you could get away with grinding a little material off the caliper.
Old 09-23-2009, 12:17 AM   #12
s14kouki44
I think Ima try grinding down the caliper. It just needs a slight trim. I just wanted to make sure it'd be safe to do so. Thanks for you input guys!!
Old 09-23-2009, 08:09 AM   #13
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
You can have a local machine shop flycut the Nissan logo off and skim
a litte off the face to get clearance.
Would look decent too.
Old 09-23-2009, 08:16 AM   #14
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
do you guys read?
the BARREL doesn't clear.
i mean it depends on how much filing you will do. 1 mm is the MAX you should file.
also, depending on where you got the adapters for the z33 track rotor, maybe whoever made them made them to sit the caliper a little too high. na mean?
clark is offline   Reply With Quote
Old 09-23-2009, 11:56 AM   #15
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
i had this problem too.
FML..
fastest fix was getting 18s.
you could grind down the caliper.
a spacer might only help if the barrel is tapered. and only if the inside diameter of the wheel increases away from the face.
Marcus is offline   Reply With Quote
Old 09-23-2009, 01:02 PM   #16
trsilvias13
I have your set up. 350z track rotors with z32 calipers. Fits under 17in grams lights pros - same wheel marcus has in his pic.
Old 09-23-2009, 01:49 PM   #17
chrisa
chrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfection
Send a message via AIM to chrisa
i have Z32 brakes and they fit in my Advan 16's!!!! i would just another set of wheels.
chrisa is offline   Reply With Quote
Old 09-23-2009, 03:03 PM   #18
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Did you not read the thread? There talking z32 with 350z rotors.
Get pic of the rubbing and then we'll answer all your questions.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 09-23-2009, 06:11 PM   #19
s14kouki44
[QUOTE=Marcus;3043393]i had this problem too.
FML..
Just like this but not as bad. I'd get 18's if it meant not grinding down those gorgeous calipers but mine are just z32's haha so it should be ok. I'll try to get a pic but no digital cam at the moment. Thanks guys
Old 09-23-2009, 11:10 PM   #20
OptionZero
OptionZero's Avatar
had the same problem. Caliper rubs the inside of the barrel. Spoke clearance is no issue
17x9.5 XD9's are built for use in rear. Apparently work didn't consider S-chassis owners' brake options.
get new wheels
