![]() PICTURES: Pictures by Duke679 - Photobucket
Clean Title SE 93' Features: Air conditioning Cruise control Power locks Power windows Sunroof Leather seats MANUAL SMOGGED 1 MONTH AGO. Engine: 93’ KA24DOHC 55k Miles New HKS 3' Cold Air Intake. ( With CARB Sticker ) New Valve Cover Seal New K&N fuel filter. Professionally Installed / Done By Dave’s Muffler Shop: New Custom 3 1/4' Straight Pipe Flow Master (CAT OFF) with resonator, 1PSI back pressure. CAT comes with car too. New Exhaust just put it on it’s a slip on exhaust which sounds like a straight pipe muscle car, and I also have the stock exhaust which is a slip on. It takes about 10 minutes or less to switch the exhaust out without a lift. 2 feet behind the rear bumper is a clamp held together with 2 bolts and u just undo and it will slip right off and u can add the stock exhaust system. Loud Exhaust = Straight Pipe w/tip. Stock = Sleeper effect. Transmission: Professionally Installed / Done By Strike Speed Auto & Works Motor Sports: New Act 6 Puck Sprung Clutch with Heavy Duty Pressure Plate Re surfaced Fly wheel ACT 6 Puck Clutch Kit for the KA24E/KA24DE is rated to hold 342 foot pounds of torque! It comes with the heavy duty pressure plate, sprung 6 puck disc, throw out bearing, pilot bearing. Changed all the oils less than 300 Miles Ago Some fewer than others. Engine Oil Motul oil Transmission Oil Mobile 1, Diff Oil Motul oil power steering fluid Standard Suspension: Professionally Installed / Done By Strike Speed Auto & Works Motor Sports: Corner Weighted 49.6/50.4 was the Corner Weight Distribution! Weighted And Proven By Works New Tein Super Drift adjustable Coilovers . (Green) Front Left Tein Tie Rod (Green) Front Right Tein Tie Rod (Green) Front God Speed Sway Bar (Green) Rear God Speed Sway Bar (Green) New Tein Upertower Sway Bar. Energy Suspension Polyurethane Steering Rack Bushing (RED) Energy Sway Bar End Link Polyurethane (Red) FRS Aluminum Steering Bushing Stance ST2 Aluminum Subframe Bushing ( Gold ) ** Wielded Reinforced Subframe Professionally Done Painted Green with Gold Flakes. ** Kit worth over 2500 Dollars!! But better! This Car handles like a Go-Cart Quick Responsive Aggressive Handling. And a Wielded DIFF 4 New H&R special ordered S13 25MM spacers. with a 5mm slip on behind spacer. -4* Degree Camber Suspension And Adjustments were all Professionally Done By: Strike Speed Auto ( SS Auto ) And Works Motor Sports. Brakes: Porter Field R4-S Brake Pads in the front and Rear, High Carbon Compound. New stock Rotors from S14. Interior: Professionally Installed / Done By Strike Speed Auto & Works Motor Sports: Professionally Installed: New Works Bell Quick Release * With LOCK COVER * Silver Professionally Installed: New Sparco Deep Dish 325MM steering wheel. 2 New Kirkey intermediate road racing seats. 2 New Bride lowering brackets and sliders. 2 New Kirkey Foam seat covers with black stitching. ---------------------------------------------------------------------------------------------------------- Professionally Installed: By My friend! New Carpet (Black) New Head liner (Black) Leather Dash ( Two Tone Leather black and silver ) Door Panels ( Black Leather with silver Lining ) Leather Back seat with <TAPOUT> logo Exterior: Professionally Done: High Quality Paint with Glitter in it; cost around 5k to replicate! (Silver) 4 New Ichiba 5 lug conversion 4 New H&R special ordered S13 25MM spacers. with a 5mm slip on behind spacer. 4 New 17' Drag Replica RPF1 Rims Black with Chrome Lip. 20 New Custom Titanium Extended Works Lugnuts. 4 New Lexani tires with 500 miles on them. High GRIP __________________________________________________ ______________________ Thanks for looking at my 240, This 240 is practically rare. I don’t believe there is another like it, It has 55k ORIGNAL miles and I’m the second owner! Everything about this car is reliable and fast! It is NOT stock!!! The motor is a perfect running condition raced only a few times for testing suspension, The motor is very strong no proof of Dyno but I feel 170 HP. Never has seen a drifting competition yet, but if you delay any longer I will have to take it out. $3,00 SR20 240’s are great… for a beater. I’m selling a real deal suspension completely finished with no other upgrades necessary. Take this car around a tight track, and the SR20’s with stock suspension will be crying. All the work done to this car was done by either Strike Speed Auto or Works Motor Sports. The Exhaust was done by Dave’s Muffler Shop, The Exterior and Interior were done by a friend with over 20yrs in the bis. and was completely restored 150% with thick glitter paint silver and two tone leather that is very elegant and durable. I can provide proof of anything that you might question, I will waste my time with ‘Flamers’ who have no money and have a lot of jealously. I’m going to add updated pictures of the car maybe even a video and I’ll try to get pictures of the suspension and other upgrades. I recommend coming in person to really grasp what this car is all about, I can get it to a shop so It can be racked for you to view. Pictures are on my Photobucket. PICTURES: Pictures by Duke679 - Photobucket 240’s have a reputation of being a cheap drift car, I’ve taken its reputation and scaled it with RX-7’s, S2000’s and other priceless cars; I’ve turn it into a show car with everything up to hot rod standards. This is one of the finest 240’s on the street I’ve added all these upgrades in a 3month period to reassure you they are 100% brand new hardly broken in but tested. It was painted and refurbished this year. ** The car is currently at Srike Street Auto getting the reinforced Subframe done ** That's how NEW these upgrades are. I’ll bring it home this weekend. Test Drive with Money in Hand NO APPCEPTIONS $9,000 or best offer 9,000 is the lowest im going! I have 2,000 dollars of work being done to this car alone this week! I should charge 10k If you have any questions, or comments you can call me (707) 583-6640 Email: [email protected] Aim: [email protected] Thanks, Duke Last edited by S13 Duke; 09-24-2009 at 02:21 AM.. Reason: Adding more things i did to it. |
Thanks, I didn't know what the exact the parts were last time i posted it but i spent time looking them up. I'll have the pictures updated next week hopefully when i bring it to the muffler shop to work on the back pressure ill get some good pics in. The exhaust sounds crazy XD and the slip on stock one still sounds stock!
![]() Join Date: Jun 2004
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
you feel it huh? hmm......okay. 9K, good luck with your sale.
My car is looking for a new home. Buy my car today! ![]() |
R.I.P. Aya, always love
![]() Join Date: Nov 2001
Trader Rating: (215)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 215 reviews
Eh nevermind.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
Okay.. Here comes the Defender!
"thats an ebay intake." Reply: Yes It's a Ebay intake but i taped HKS and the Vin Number on the metal so it would match the carb sticker. Soo you can get a name brand then get a fixit ticket for it. "Eh nevermind." Reply: ??? Very Nice car!! but 9000? "$9,000 or best offer 9,000 is the lowest im going" Then its not OBO, its FIRM. Reply: Ya your right, but someone could offer me more haha...XD Quote: Originally Posted by S13 Duke ![]() The motor is a perfect running condition raced only a few times for testing suspension, The motor is very strong no proof of Dyno but I feel 170 HP you feel it huh? hmm......okay. 9K, good luck with your sale. Reply: Ya i figured after owning several ricers i can predict the power. It's not often you drive a well taken care of car so it hasn't lost much power. "wow you're on crack" Reply: Wow your jealous "thats a lot of money" Reply: Eh i have like 16k now in the car. paying proffessionals to make adjustments cost alot of cash. I love critisim, it just bumps my post to the top so people who dont troll all day and have money can actually buy a nice car. Thanks Keep it coming! |
#15 |
^^^ i actually LOL'd haha
Fine ass looking coupe, wish mine looked like that lol! GLWS duke, hope you get your moneys worth
I drift, I drive, I jerk |
#16 |
![]() Join Date: Mar 2009
Trader Rating: (24)
![]() ![]() Feedback Score: 24 reviews
The only thing i like on the car are the coilovers and the paint job the rest is garbage and you must be as high as the price of this fast and furious car..... and the tapout back seat is so gay!!you might get 5k for your car...FAIL!! post this on ebay (just like the exhaust and intake) or craigslist cause it wont sell for 9k on here.
#17 | |
![]() Quote:
Just what I expected from a guy who posts a picture of his wife/GF holding hands. Apparently your wife is going to fund your relationship, obviously your to ignorant to read that the exhaust is custom made. “fast and the Furious car"? You must have a truck to haul your ignorance around..You’re on a website full of fast and the furious cars maybe you can look at the advertisement on this website. "Post this on Ebay" are you saying Ebay sucks? You truly are a fool. Nice hair lol....homo |
#18 |
![]() Join Date: Sep 2008
![]() Feedback Score: 14 reviews
Alright, this is one of the cleanest coupes I have ever seen.
I can see how you have $9k invested, but I think you should probably hope for a solid $6k at the top of the market. New paint, and good footwork will put you close to 4, all of the other stuff is kind of just a "please buy me" type of thing that nobody really pays attention to...refurbished interior, intakes, etc. It's kind of a giveme on these cars. Definitely a beautiful car, but I don't think you'll be able to get any more than 5 or 6 out of the car at the top of the market no matter how perfect it is. |
#20 | |
Trader Rating: (24)
#21 | |
#23 |
![]() Join Date: Mar 2007
![]() Feedback Score: 10 reviews
Shouldn't have lied about the intake man, see what the mods think about that. Also this whole thing is ridiculous, the suspension is nowhere near done like you claim it is. I take it that -4 degrees of camber is only in the front?(since you don't have adjustable RUCA's)
Also, what is this "Kit worth over 2500 Dollars!!" and pics of the subframe reinforcement? What in the exhaust system is flowmaster? Maybe if you get rid of that Tapout crap you could get more for the car. |
#24 | |
"Im the homo but you looking at my pic and my hair wow...whos the homo now" What? That makes on sense your posting a pic of that because you want attention of other males..homo. God Speed Sway bars for the s13..Those are one of the biggest sway bars you can get for a S13 obviously only name brands interest you, who makes the gel for your hair? Macy's?..lol.. "Pleather Seat" you really can't read can you? It's a Tweed fabric most Kirkey seats are like that and it's a seat cover, Kirkey seats are normally made of metal. Why do people hate Tapout? lol I'm trying to sell a car your ruining this post go gel your hair... go away. |
#25 | |
Trader Rating: (24)
^^^^ Enough said i dont talk shit to people who have clean cars but when you start lying about your parts and what you did to your car and how much you have spent!and then try to sell it for 9K!! that pisses me off |
#26 |
Bigger is better is the ricer/fast and the furious approach to sway bars. You can easily go to big and different sizes on different ends of the vehicle suit different driving disciplines.
#27 |
Trader Rating: (24)
IM sorry but i had to add this cause this is funny as hell i promise this is the last time i will say anything about what you have wrote on the description of your car...LOL
SR20 240’s are great… for a beater. I’m selling a real deal suspension completely finished with no other upgrades necessary. Take this car around a tight track, and the SR20’s with stock suspension will be crying. |
#28 | |
![]() Quote:
mk, a cold air intake from Ebay, stamped with HKS in big letters so when it gets smogged/inspected by cops etc a carb sticker is there, I’ve already stated that it is a EBAY intake. There is no difference between HKS intake and Ebay they both serve the same purpose when it says " dyno proven " it's dyno proven because it is a upgrade from stock. I would like to see Dyno Proven from a Ebay intake most likely no difference. -4 Degree camber is correct, that's what works told me it looks the same as the front I obviously didn't sit there to make sure but I doubt they would lie about it. I am planning on putting on some Ruka’s though. To get a nice subframe reinforcement kit & labor cost around 2500 to get a FULL kit and labor done to it. I will get it back soon and rack it to show how built it is, nonsense how many people have doubts when they haven't even seen the car in person. Out of 600 views how many people actually wanted to buy a S13 almost 3/4 of views were people searching for something to argue about. Give it a rest PM me if you want to fight about something don’t ruin my post because your hating. Some people actually have legit questions that's cool comment on it once then PM me the second time. |
#29 |
![]() Join Date: Jan 2003
a bit overpriced. ive seen swapped kouki's with wheels, paint, etc for 10k. clean car. but good luck gettin 9k. my buddy is selling a full-race ka-t s14 for 10.5k. sounds crazy to pick up a stock ka for 9.
TEAM SKIDMARKS Carbon black S13 SR Coupe |
#30 |
![]() Join Date: Sep 2007
![]() ![]() ![]() Feedback Score: 12 reviews
whats so rare and special about this car is what i would like to know that you think its worth 9K? lets be realistic here,all those parts you put into it are cheap. you might as well part the parts off and sell a stock coupe for a reasonable price. you cant ever get the money you've put into a 10+ year old car back.. nonetheless its a clean car. GLWS
