Old 08-26-2003, 06:22 AM   #1
nomorehondas
nomorehondas is an unknown quantity at this point
lifted hood ala nadine180.com
so i bought an ebay front strut bar and the damn thing hits my hood. now i have a dented hood, sore fists and a hole in the plaster. anyone know how to do that hood lift/angle like nadine has? do i need to machine some kind of blocks to go between the hood and the hinges or is there a simpler way? please help, i hope if i fix it fast enough i can push the ding out of my hood. thanks
graham
nomorehondas is offline   Reply With Quote
Old 08-26-2003, 08:01 AM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
i got some longer bolts and shoved some old lugnuts between the hinge and hood (bolts go through em). works for me.
AceInHole is offline   Reply With Quote
Old 08-26-2003, 09:52 AM   #3
deviousKA
deviousKA's Avatar
deviousKA is making a name for him/her selfdeviousKA is making a name for him/her self
Send a message via AIM to deviousKA
i have probably the same strut bar. mine also sat to high and was going to hit hood. you have to flatten it out (i shoved it between 2 planks on my houses deck and bent it) or you could use a vice with a rag wrapped around the bar so you dont scratch
deviousKA is offline   Reply With Quote
Old 08-26-2003, 11:34 AM   #4
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
yawn..
its a bar, bend it. that whole hood prop thing is laaa-me.
old_s13 is offline   Reply With Quote
Old 08-26-2003, 08:32 PM   #5
nomorehondas
but its a solid aluminum bar, can u bend those safely?
Old 08-26-2003, 09:36 PM   #6
mike91se
mike91se's Avatar
mike91se is an unknown quantity at this point
i got a cheap-o strutbar, was too high
took a towel and a sledgehammer to it
my friend stood on the end while i hammered the middle flat.
dont hammer the end of the bar because you will make the screw hole you put the end connector smaller (crush it pretty much) and the end piece wont fit.
mine fits perfectly now
still kinda iffy that im using a home-bent STB, o well, it works.
mike91se is offline   Reply With Quote
