Old 08-26-2003, 01:38 PM   #1
240KAT
240KAT's Avatar
240KAT is a well-known jackass
Send a message via AIM to 240KAT
passenger window not working
Well, the subject is really what the problem is. fortunetely, its stuck in the up position. The driver window works fine. As do the passenger door speakers and power sideview mirrors. I think theres only one fuse for the power windows, so that cant be bad. Any ideas? OH, i have an S13 SE
Drew
240KAT is offline   Reply With Quote
Old 08-26-2003, 10:46 PM   #2
240_keyy
240_keyy's Avatar
240_keyy is an unknown quantity at this point
Send a message via ICQ to 240_keyy Send a message via AIM to 240_keyy Send a message via Yahoo to 240_keyy
did you check the "Power window lock" button just in front of the drivers side window switch? if it is pressed in the pass side windo will not go up...
There *is* a spoon...
240_keyy is offline   Reply With Quote
Old 08-26-2003, 10:51 PM   #3
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Relay or window motor. Sometimes the relay/switch can be stuck in one position and the motor burn out by staying "on"...in your case in the closed position. Look on ebay...the whole PW guts go for like $80 or so.......or check a junkyard. You could take out the motor and test it...if it works then its the relay.
-m
mbmbmb23 is offline   Reply With Quote
Old 08-26-2003, 10:52 PM   #4
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
Or possibly the connection to the window button isnt in all the way.
Can you roll the pass windo from the driver side? If so then it might likely be the power lock button, if you can move it down, check the connection first.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 08-27-2003, 09:58 AM   #5
Dream240
Dream240's Avatar
I had a similar problem with my s14 passenger side window. The dealer siad the motor fell off it's hinges and woudl only roll halfway down. They rebolted everything and locled it down and it works fine now. If you're not mechanically inclined, take it to nissan, at least they'll find the problem for about 60 bucks? Pricey but then you'll at least know what is wrong.
Old 08-27-2003, 01:05 PM   #6
240KAT
240KAT's Avatar
Wow..i feel like a complete ***, however. I'm glad I asked you guys. Lol, i mustve nicked my window lock button at some point. I wouldve never checked that either. Works fine now. Cheers!
Drew
Old 08-27-2003, 03:46 PM   #7
Dream240
Dream240's Avatar
Hey don't beat yourself up. I do that almost everytime I clean the interior. Get in, hey windows not working...duh it's the switch.
