Old 09-28-2009, 12:58 AM   #1
skazee27
skazee27 is an unknown quantity at this point
s13 WTB top feed injector o rings ka24e
title... pm or post
skazee27 is offline
Old 09-28-2009, 01:06 AM   #2
THeokaYsLider
THeokaYsLider's Avatar
THeokaYsLider is an unknown quantity at this point
al you have to do is drive to home depo or lowes and buy the rings there just take ur rail ad injector to match it up and thats all can run up too 2 dollares only
THeokaYsLider is offline
Old 09-28-2009, 01:14 AM   #3
skazee27
s13
oh thats cool i didnt know they had rings, ill go check them out, just wanted to make sure on the size.. hey arent u the foo about that seats? did u ever find out about the ones u had, i found out the sohc coupe has them, my friends coupe had hers just like the picture,
skazee27 is offline
Old 09-28-2009, 01:35 AM   #4
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
i wouldn't get them from home depot. when a manufacture designs a system such as a fuel system they use parts that can withstand the elements that they're exposed to. good old home depot o-rings won't be able to withstand gasoline. they'll break down because they're not the same rubber composition as oem rings. you'll fuel leaks and further engine problems.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline
Old 09-28-2009, 11:06 AM   #5
Jdm_of_miami
Jdm_of_miami is a glorious beacon of lightJdm_of_miami is a glorious beacon of lightJdm_of_miami is a glorious beacon of lightJdm_of_miami is a glorious beacon of lightJdm_of_miami is a glorious beacon of lightJdm_of_miami is a glorious beacon of lightJdm_of_miami is a glorious beacon of lightJdm_of_miami is a glorious beacon of lightJdm_of_miami is a glorious beacon of lightJdm_of_miami is a glorious beacon of lightJdm_of_miami is a glorious beacon of light
I got the injectors with the rail.. $75.00 shipped
Pm me for more info
Jdm_of_miami is offline
