Old 10-18-2009, 04:10 PM   #1
Rockda240
Rockda240's Avatar
Rockda240 is making his/her stupidity well-knownRockda240 is making his/her stupidity well-knownRockda240 is making his/her stupidity well-knownRockda240 is making his/her stupidity well-knownRockda240 is making his/her stupidity well-known
Send a message via Yahoo to Rockda240
s14 Help Brakes keep locking up!!!
I am in need of some serious help, my brakes keep locking up, I did a full z32 conversion bled the brakes twice and for some reason the shit just keeps locking up on my ass!
Rockda240 is offline   Reply With Quote
Old 10-18-2009, 04:16 PM   #2
armand
armand's Avatar
armand is on a distinguished road
Send a message via AIM to armand Send a message via Yahoo to armand
take off your brake master cylinder, and try adjusting the rod on your brake booster. i had the same problem a few years ago and that fixed it
armand is offline   Reply With Quote
Old 10-18-2009, 04:18 PM   #3
240sxxs
240sxxs's Avatar
240sxxs is an unknown quantity at this point
drive slow and brake from distance = problem solve
The pretty one Arn't free and the free one Arn't pretty
240sxxs is offline   Reply With Quote
Old 10-18-2009, 04:39 PM   #4
Rockda240
Rockda240's Avatar
does the push rod just spin or do you have to pull it then turn or what? I checked the fsm, no such luck.
Old 10-18-2009, 04:44 PM   #5
punk138
punk138's Avatar
punk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond repute
i recently had the same problem, i changed out the entire brake booster and now everything works great. but im running the stock s13 booster not the z32...
yes we still roll fenders
punk138 is offline   Reply With Quote
Old 10-18-2009, 09:48 PM   #6
Rockda240
Rockda240's Avatar
So how the hell do you adjust the pushrod?
Old 10-18-2009, 10:20 PM   #7
ericb382
ericb382 is an unknown quantity at this point
Hold with needle nose, twist. Done.
ericb382 is offline   Reply With Quote
Old 10-19-2009, 12:10 AM   #8
Rockda240
Rockda240's Avatar
alright, thank you!
Old 10-19-2009, 01:47 AM   #9
P-Funk alot
P-Funk alot's Avatar
P-Funk alot is an unknown quantity at this point
Send a message via Yahoo to P-Funk alot
does it lock up after you brake or is it locked up at all times
P-Funk alot is offline   Reply With Quote
Old 10-21-2009, 04:57 PM   #10
Brye
Brye is a splendid one to beholdBrye is a splendid one to beholdBrye is a splendid one to beholdBrye is a splendid one to beholdBrye is a splendid one to beholdBrye is a splendid one to beholdBrye is a splendid one to beholdBrye is a splendid one to beholdBrye is a splendid one to beholdBrye is a splendid one to beholdBrye is a splendid one to behold
I'm having the same problem.
I've changed the brake booster, master cylinder, and brake booster check valve. All at the same time.
It used to lock up only at high speed sprints, and stop and go traffic. Now, it's just driving it locks up.
I'm thinking it's pulling too much vacuum but I don't know how to check how much vacuum it's pulling, and how much it should pull.
I'm having to pull the vacuum hose from the check valve on the booster side to release the brakes. So, I'm guessing it's retaining vacuum on the booster side.
Brye is offline   Reply With Quote
Old 10-23-2009, 10:02 PM   #11
Rockda240
Rockda240's Avatar
it locks up while I am braking.
Old 10-23-2009, 10:12 PM   #12
mazersx
Banned from the Marketplace
Trader Rating: (32)
mazersx is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to mazersx
CHANGE THE BRAKE MASTER CYLINDER? 17/16 or 1" 1/16
mazersx is offline   Reply With Quote
Old 10-23-2009, 10:23 PM   #13
Rockda240
Rockda240's Avatar
I already replaced the master cylinder!!! From 240 to z32 17/16"!!! Replaced basically the whole brake system except the booster!
Old 10-23-2009, 10:59 PM   #14
93nismo
93nismo's Avatar
93nismo is an unknown quantity at this point
if adjusting it dosent work just replace it. make sure the hose going to it is good as well.
WTB: 1/24 scale chuki s13 model.
93nismo is offline   Reply With Quote
Old 10-23-2009, 11:09 PM   #15
super240s14
super240s14 is an unknown quantity at this point
i have that problem here and now, i think it could br the calipers seizing but not 100 % sure lol, i know thats the problem with mines, and if not then change your mc back to your old mc if you havent done so
super240s14 is offline   Reply With Quote
Old 10-23-2009, 11:29 PM   #16
ericb382
What locks up? Front, rear, both? Are you saying that when you let go of the pedal it keeps breaking, or that when you hit the breaks you lock the tires up?
Old 10-23-2009, 11:43 PM   #17
gsxr141
gsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymore
the fronts on my 240 would lock up after about 20 min of driving. i replaced the master, then the hoses. it ended up being the calipers sticking on. make sure the calipers you got are good.
gsxr141 is offline   Reply With Quote
Old 10-23-2009, 11:47 PM   #18
Rockda240
Rockda240's Avatar
yeah when I stop and let off the pedal and then go to press it down again, the brake pedal doesn't go down at all.
Old 10-23-2009, 11:49 PM   #19
Rockda240
Rockda240's Avatar
is there a way to adjust the pushrod from under the dash? I undid the locknut but I don't see how to shorten it. Is there any specific site that can help me with this? Maybe even pics?
Old 10-23-2009, 11:54 PM   #20
silviaconcept
silviaconcept's Avatar
silviaconcept is making a name for him/her selfsilviaconcept is making a name for him/her self
adjust your pedal
silviaconcept is offline   Reply With Quote
Old 10-25-2009, 02:10 PM   #21
ericb382
That doesnt' sound like the MC adjustment. That just fixes mushy pedal/free play in the pedal. Basically how far you have to puch the pedal before you start getting engagement. That deffinately sounds like the caliper(s) seizing up.
Old 10-26-2009, 01:32 AM   #22
Rockda240
Rockda240's Avatar
Yeah I just replaced the master cylinder. I think I just need to adjust the pushrod or something is wrong with the brake booster, I just replaced everything else.
Old 10-26-2009, 01:50 AM   #23
Rockda240
Rockda240's Avatar
my whole point is that it was adjusted and it won't disengage!
Old 10-26-2009, 09:00 AM   #24
ericb382
Ok, then try backing the rod off, if it works then that was your problem.... Look in the FSM, it covers how.
